390 timing chain
Old Jul 15, 2013 | 04:13 PM
abyars111's Avatar
abyars111
390 timing chain
I'm going to be changing the timing chain set on my 390. It is my understanding that Ford retarded the timing 4 degrees on this engine sometime in the mid seventies and before then the standard timing chain set the timing straight up. Is this correct?
I looked up a timing chain for a 1970 390 and the part number is different from a 1976 390. So to ensure I get the timing set "straight up" should I go and get a standard timing set for a 1970 390? I see some sets that offer adjustability but that just confused me.
Old Jul 16, 2013 | 11:28 AM
Freightrain's Avatar
Freightrain
Get the 1970 model.
The typical factory replacement version has only ONE keyway. No adjustability. The aftermarket versions range from 3-9 different keyways in the crank gear. This is to enable you to adjust the camshaft timing slightly. Advancing the cam bring the power in sooner, retarding it moves it up the rpm scale slightly. To do this correctly you need a degree wheel and indicator to find the opening/closing points of the cam and work from there. In performance applications this is common practice.
For a stock replacement, putting it in "Straight up" is the way to do it(meaning no advance or retard). You may find that even the generic version you buy has 3 keyways. Just follow the instructions on which one to use. Usually they are marked with a triangle, rectangle and circle. One is straight up, the other are 4* adv and 4* retard.
Old Jul 17, 2013 | 10:32 AM
baddad457's Avatar
baddad457
The timing set isn't retarded, the cam is ground that way. I've never seen a 4* retarded timing set.
Old Jul 17, 2013 | 12:15 PM
riverguideguy's Avatar
riverguideguy
ive heard the same thing about timing sets being retarded 4 degrees after 72. i know when i went to napa they seemed to back this up cuz there was 2 different part numbers for 71 and 73
Old Jul 17, 2013 | 03:06 PM
baddad457's Avatar
baddad457
If it were (the timing set) the keyway and the alignment dots would not be in line with each other. Ain't seen one yet that was like that, and I've taken apart a lot of engines with factory timing sets.
Old Jul 17, 2013 | 03:58 PM
abyars111's Avatar
abyars111
Thanks. My worries are put to bed now.
Old Jul 17, 2013 | 08:33 PM
baddad457's Avatar
baddad457
The only way to really know at this point in time is to have the cam specs handy and using a degree wheel, check to see where it's at with the cam that you have.
Luch
Apr 12, 2013 10:02 PM
wild bill pbr
Jun 6, 2007 06:26 PM
AirSmitty
May 13, 2004 08:46 PM
xman7896
Dec 10, 2003 07:53 PM
big block power
Nov 24, 2002 11:42 PM
