Identifying a Rear End
Old Dec 12, 2004 | 07:07 PM
bremen242's Avatar
bremen242
I am stating you don't need overdrive when you have 2.73 or 2.47 rears. I am _not_ stating that there is no need for overdrive. Personally, on my 300-6 with 2.47 gears, I noticed a gas mileage increase from 12 to 15mpg when I swapped to 3.50 gears.
However, I live in a state where you are constantly going up and down hills.
If EPA ratings in '83 were so great and truck ran 2.47 - 3.08 gears, then why to most trucks now run at least 3.55 gears and overdrive?
My current F150 has 3.08 gears which, IMHO, is the best match for fuel economy and having a truck that isn't a total dog.
any stock 300-6 powered trucks that have 2.47 rears is a dog.
I should also note that most manufactures state that overdrive shouldn't be used under 55 or when towing.
I will also state that I installed an OD tranny later on after I swapped the 3.50 gears. good power + good economy.
Old Dec 12, 2004 | 07:21 PM
fordfan302's Avatar
fordfan302
so bremen you have 3.50 gears with a granny gear 4 speed???
Old Dec 12, 2004 | 07:36 PM
bremen242's Avatar
bremen242
I had a 3 speed on the column.. I swapped in a 3spd w/ OD.
Old Dec 12, 2004 | 07:39 PM
fordfan302's Avatar
fordfan302
Well do you think 3.50's will work good with a granny gear 4 speed????? Would it make the gas mileage any better or any worse?????
Old Dec 12, 2004 | 07:48 PM
bremen242's Avatar
bremen242
if you have a 302, 3.50s would work great with a regular 4 speed.. it is a little steep on a stock 300 though.
Old Dec 12, 2004 | 07:49 PM
fordfan302's Avatar
fordfan302
how about gas mileage does it increase or decrease?????......BTW i do have a 302
Old Dec 12, 2004 | 08:25 PM
bremen242's Avatar
bremen242
what gears do you have now?
Old Dec 12, 2004 | 08:28 PM
fordfan302's Avatar
fordfan302
im pretty sure theyre 2.42 or 2.73.......not positive though
Old Dec 13, 2004 | 06:40 AM
bremen242's Avatar
bremen242
I'd probably expect it to climb a little, as long as you don't do a lot of freeway miles. the 302 has a higher power band then a 300, so you want to be over 2500 rpms when driving 55. You'll notice a lot more power, for sure.
CDF302v8
86
Jun 29, 2018 09:34 AM
78fordcustom
15
Sep 28, 2010 08:00 PM
JaysRanger
1983 - 2012 Ranger & B-Series
Jan 14, 2009 05:14 AM
chrono4
Jan 26, 2005 09:51 PM
skycarpslayer
Mar 4, 2003 07:08 PM
