Identifying a Rear End
Old Dec 11, 2004 | 08:31 PM
fordfan302's Avatar
fordfan302
How would i tell what kind of rearend i have????? I would like to know if its an 8.8 or a 9 inch and what kind of gears it has.......Can anyone Help Me?By The Way...It's a '86 F-150, 302 EFI, 4X2, 4 speed granny gear
Old Dec 11, 2004 | 08:59 PM
Mr. Finch's Avatar
Mr. Finch
I havn't done much rear end work, but counting the bolts on the pumpkin should give you an idea. But I don't know how many bolts are on the diffrent sizes.
Old Dec 11, 2004 | 09:58 PM
bremen242's Avatar
bremen242
it is more than likely an 8.8" rear. very few 9" rears went into trucks after '83. if it has bolts on the back of the housing, it is an 8.8. if not, a 9".
Old Dec 11, 2004 | 10:01 PM
fordfan302's Avatar
fordfan302
infact if your behind the truck and bend down and look at the differential there are no bolts.......so i guess thats good news......i was hoping i had a 9 inch thanks alot
Old Dec 11, 2004 | 10:05 PM
bremen242's Avatar
bremen242
if it has no bolts in the back, it _is_ a 9".
Old Dec 11, 2004 | 10:44 PM
1982fordf100's Avatar
1982fordf100
And for the gear ratio look at the data plate attached to one of the studs on the differental. Write all the numbers down on it and post it on here.
Old Dec 11, 2004 | 10:57 PM
fordfan302's Avatar
fordfan302
i looked for the numbers and i couldnt find them.......i look tomorrow because its 30 degrees outside and its 12:00 at night LOL, but if you could be more specific about exactly where the numbers are
Old Dec 12, 2004 | 01:28 AM
85F_150driver's Avatar
85F_150driver
there should be a sheet metal tag about 1/2 to 3/4 inch wide and prolly 2 inches long. it will be attached under a bolt on the houseing. if its not there then post the code from the door jam if it has not been changed that should give you a good idea.
Old Dec 12, 2004 | 10:55 AM
Mr. Finch's Avatar
Mr. Finch
I have wondering the same thing about my truck. it is an 81 f100 4spd od and it sounds like a 9'' rear but the tag is missing. On the door the only thing it says about the axle is that it an 02, but doesnt that just mean that it is a 2 axle truck?
Old Dec 12, 2004 | 02:11 PM
bremen242's Avatar
bremen242
you have a 9", and it is probably the dreaded 2.47 or 2.73 rear.
Old Dec 12, 2004 | 05:09 PM
Mr. Finch's Avatar
Mr. Finch
What is so bad about the 2.47 and 2.73?
Old Dec 12, 2004 | 06:10 PM
bremen242's Avatar
bremen242
They keep your motor at a super low rpm when cruising. You probably don't use overdrive, do you?
normally, people think the higher the gears (numerically lower) the better the gas mileage. When you have a super high gear (like 2.47s or 2.73s), you suck more gas b/c you have to keep flogging your motor to climb up and down hills. Those gears are probably fine for someplace flat (like kansas or the dakotas), but for hill country (like Western PA, where I live) you have to keep shifting.
Old Dec 12, 2004 | 06:17 PM
8 Lugs's Avatar
8 Lugs
Almost sounds like he's got 2 eye patches, dosen't it?
Old Dec 12, 2004 | 06:46 PM
srercrcr's Avatar
srercrcr
Bremen, you my friend have it all wrong.
Why do you think they offer overdrive? to get worse mileage?
Check the EPA ratings, check testimonials on this site.
My 83 300 Supercab, 8 ft bed 3.08 axle got 22 mpg when new, now 20 highway, 15 otherwise.
Old Dec 12, 2004 | 07:02 PM
Mr. Finch's Avatar
Mr. Finch
Actually I live in Dekalb Illinois (a little west of chicago) near Northern Illinois University, and except for the intown 30 mph I use od alot. You are right though that it is probably not the best to have in realy hilly areas, but in thoes areas if you use a standard 4spd and leave it in 4th you are pretty much using the same gear as the od 3rd so it is probably worth it to have the od and just shift a few more times.
