Sponsored by: Real Truck
Speedometer messing up..
Old Dec 10, 2004 | 08:15 AM
RobertJohn's Avatar
RobertJohn
Has anyone had a problem with their speed ometer ? Mine just started messing up. It quits working at 30 mph or less.. Just drops off or down to zero.
This is a 1999 F-250 diesel 4x4..
Any suggestions ?
Old Dec 10, 2004 | 08:22 AM
Fordafied's Avatar
Fordafied
You may want to check the VSS (Vehicle Speed Sensor) on top of the rear diff. You can take it out and clean it and see if that works or just replace it. I bought one from the dealer at $24. It only has one bolt holding it in and has a magnetic pick-up on the bottom that sometimes get metal shavings covering it. It has one plug for the wires. real simple. This may be it or not. Just a starting point.
Old Dec 10, 2004 | 08:38 AM
Tjdb2000's Avatar
Tjdb2000
Smile
Yep, Sounds like the old VSS. My 99 250 CC 4X4 did the same exact thing a couple months ago. It is a cheap easy fix.
6ohpowerstroke
Nov 7, 2014 06:16 PM
frenchy107
Mar 5, 2011 07:38 PM
mountaindufreak
Sep 16, 2010 12:41 PM
tex25025
Texas Chapter
Jun 6, 2010 10:22 PM
abigaildevore
Sep 8, 2006 08:59 PM
