4x4 help
Old Sep 14, 2010 | 09:22 PM
mountaindufreak's Avatar
mountaindufreak
4x4 help
i was wandering how hard it would be to replace the u joint in the right side axel. i have never messed with the hub or axel and i really dont want to mess any thing up
Old Sep 15, 2010 | 06:49 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...-u-joints.html Have a read here. You would not have to go as far as the ball joints (unless found to be bad).
Old Sep 15, 2010 | 12:08 PM
mountaindufreak
thank you i will look at that
Old Sep 15, 2010 | 08:39 PM
mountaindufreak
i was wandering what was in the rubber boot and if i could
take the axle apart there like a cv joint on a front wheel drive car
Old Sep 16, 2010 | 07:00 AM
Lazy K's Avatar
Lazy K
There is another u-joint and a splined slip joint inside the boot. You can remove the boot clamp, mark the axle shaft so you can slide it in as it came out and pull the outer axle shaft out from the slip joint.
It is unlikely that the u-joint inside the boot will need replaced but check it just to be sure.
Old Sep 16, 2010 | 09:36 AM
jplinville's Avatar
jplinville
Make sure to replace any broken clamps on the rubber boot...I ended up using strong zip ties on mine.
Old Sep 16, 2010 | 12:41 PM
mountaindufreak
thank you guys this really helps
just-n-time
Mar 5, 2011 05:43 PM
imlost
1997 - 2003 F150
Aug 26, 2010 09:04 PM
speedracer54729
Apr 19, 2008 09:09 PM
ricstone
Nov 8, 2002 10:02 PM
