89 F150 Toggle switch on dash panel?????
Old Dec 9, 2004 | 04:42 PM
r7salvation's Avatar
r7salvation
Thumbs up 89 F150 Toggle switch on dash panel?????
Hey folks, just acquired my 89 F150 ....IGNition sw.RED/ blue wire disconnected from solenoid ST pin?????. Truck has an added toggle switch on the dash that has a hot wire from solenoid "ST" pin to energize the ignition switch RED-blue wire without going through any safety switches like the park/neutral switch on the tranny. It won't crank unless toggle sw is on to energize the RED/bl wire.
I want to return to original. The Haynes leaves me confused on how the Tranny sw works. Can somebody lead me toward the light.????.....Thanks.......R7
Old Dec 11, 2004 | 04:25 PM
r7salvation
"Gear select" or "neutral start" switch? Help !!!!
Will not crank normally through the solenoid switch. My 89 F150 has an inline 6 but I don"t know what tranny (3 speed auto).Door tag says "K". Anyway, I am getting no power out of the neutral start switch(Haynes calls it gear select switch). The switch must be internal because I see nothing on the tranny but the connector next to the speedometer cable. Can this switch go bad internally?. I need some help ,guys!!!
Old Dec 11, 2004 | 08:13 PM
ceetwarrior's Avatar
ceetwarrior
Just take the toggle off and trace the wire and resplice it back in?
Old Dec 12, 2004 | 07:06 AM
r7salvation
AOD Has an Internal Neutral Safety Switch?????
thanks Creet. I traced the wire back and it was an add-on straight to the "s" lug on the solenoid to bypass an open circuit situation in the neutral safety switch. I think I have an AOD with just a 4pin connector to an internal NSS and I have power going in but none coming out . I have Shifted through all gears while monitoring the voltmeter and the switch never makes up. Can I do anything to R & R the Neutral Safety switch or am I barking up the wrong Tranny??? I would like to return to original without the add-on toggle.
Old Dec 12, 2004 | 07:34 AM
EPNCSU2006's Avatar
EPNCSU2006
The wire coming out of the NSS to the starter solonoid is shown on my diagram as a red wire with a light blue stripe. It will only show power when the key is in the start position and the switch is either in park or neutral.
Old Dec 13, 2004 | 05:34 PM
r7salvation
Thanks, EPNCSU2006......
I have gotten this far, my Haynes manual shows RED/blue striped wire from ignition sw. going to NSS and then the same RED/bl coming out of sw and going to starter solenoid "S" terminal and distributor.
Here is my problem!...... There is a 4 wire connector to the NSS..... only 4 pins with 1.a RED/bl wire 2. BLACK/pink (for backup lites) 3. PURPLE/orange (for directional flasher) 4. WHITE/red (electric shift control module????....I assume this is a 4x4 item). This WHITE/red wire turns to RED/ with a blue slash......at the first harness connector on the firewall.
The ignition sw RED/bl is hot on "start" going to the tranny!!
Old Dec 14, 2004 | 01:57 PM
EPNCSU2006's Avatar
EPNCSU2006
I'll have to look over the wiring diagram when I get back home...I'll see what I can find out.
crandallf150
Dec 10, 2016 06:46 AM
AubreyA3
Aug 13, 2016 07:33 AM
lasthighboy
Electrical Systems/Wiring
Jul 24, 2014 05:54 AM
QwkFox
Dec 25, 2013 09:27 PM
hivolt5.0
Jun 22, 2011 08:17 PM
