Bronco II Ford Bronco II
Fuel Pump Problems
Old Dec 15, 2004 | 11:01 AM
mike L's Avatar
mike L
Originally Posted by amw_drizz
ALright when my b2 has a no-start i can not get under there to test the eletrical wires, it dies 99% of the time on very busy roads and often in the morning! around 7:00 am and 8:00 pm. i dont know could the computer have a problem in it & how would i pull codes if i dont have a code reader and cant afford one! i have a older electric fuel pump i would like to know if i can remove the low pressure (or disable it) pump and put the other pump on the fuel system... know what i am asking is can i disable the in tank fuel pump, put in another good fuel pump on the side of the fram rail or something like that and then have it run to the high pressure pump for the fuel system.can that be done with out removing the tank from the b2?
Welcome to FTE. You should post a new thread. Go to www.fordfuelinjection.com under getting trouble codes. Its easy and free. Also a Haynes manual has a ECC trouble codes section. Let us know your codes. List the flashes just how you read them. Once you get your codes start checking each part with the lowest codes first. Sometime one code is caused by another code.
So you think your intank fuel pump is going bad? <!-- / message -->
Old Dec 15, 2004 | 07:25 PM
Ken00's Avatar
Ken00
Is the fuel pump a Ford? You will have to drop the tank or cut a hole in the floor to gain access to the pump.
I have the procedure in the tech info thread at the top of this forum, "pulling eec-iv codes".
Old Dec 16, 2004 | 07:13 AM
amw_drizz's Avatar
amw_drizz
The fuel pump i have (mounted on the frame rail) no clue on what make car it is for... i was orginally going to use it on a 1930 model A tractor frame instead of using the old grav. fed fuel. i will have to get a fuel pressure tester to see if the pump can sustain around 40-45 PSI for fuel if it can i will remove the 2 pumps on it now and put that 1 on it.
Old Dec 16, 2004 | 08:40 AM
cokoliso's Avatar
cokoliso
Does a replacement distributor come with a TFI module? I thought you had to use the old one when you replaced the distributor. Your problem sure sounds like a TFI problem - usually fail after running a little while and getting hot. Then restarts after cooling down a bit.
Old Dec 16, 2004 | 11:07 AM
dirtybroncoii's Avatar
dirtybroncoii
I replaced my distributor and it didn't come with a new module. Make sure when you reinstall your new module you use Dieletric grease to keep the moisture out. if any water gets between your module and distributor it will start to corrode and cause more problems in the future.
Old Dec 16, 2004 | 05:58 PM
Ken00's Avatar
Ken00
The single pump system Ford used is a single pump in the tank, most fuel pumps are good at pushing not pulling.
Old Dec 16, 2004 | 06:20 PM
amw_drizz's Avatar
amw_drizz
i replaced the tfi module at the same time with the distrubter... off to the auto store to get a fuel pressure gauge...
Old Dec 16, 2004 | 06:21 PM
mike L's Avatar
mike L
fuel pumps
The older trucks had a hp fuel pump on the rail with two low pressure in the tanks. Then i believe ford updated it to a high pressure pump in the tanks.
Old Dec 16, 2004 | 06:30 PM
amw_drizz's Avatar
amw_drizz
i know that much... i have a 90 tank with a hp pump in the tank... but the sending unit wont work... should i just swap the pumps out?
Old Dec 21, 2004 | 05:30 AM
kittkatt's Avatar
kittkatt
Originally Posted by dvldg121
I have an 88 Bronco II with the same symptoms. I recently discovered at this site http://www.tfisettlement.com/ that it could be the Thick Film Intigration (TFI) ignition module causing the problem. There is a guy on e-bay selling these modules for 24.99 + 5.00 S&H, he said he had plenty in stock. Mine is in the mail and I will post latter if that is the problem. Just thought I would throw this out there.
How do I find the module on ebay?
THANX,
Bill
Old Dec 21, 2004 | 07:12 AM
amw_drizz's Avatar
amw_drizz
search for it in e-bay automotive... or try e-bay motors
Old Dec 21, 2004 | 05:12 PM
Sideburnz's Avatar
Sideburnz
Can anyone tell me the purpose of the TFI module? I began to wonder as I was changing my plug wires today.
Old Dec 21, 2004 | 05:33 PM
  #28
dirtybroncoii
TFI stands for Thick Film Ignition, It is the Ignition module, I have been working on how to remove and use a 70's distributor on a EFI system
Old Mar 25, 2008 | 11:03 AM
  #29
beartooth1's Avatar
beartooth1
heres a tip for i found for removing fuel pumps , loosen the bolts on the left frame rail ,then remove the bolts on the right side of the rail , then you can raise the box with enough room to get at those darn things.
RedDevil460
Aug 12, 2016 06:07 AM
ssummerangel3
Jul 27, 2015 05:27 PM
05f2505.4
Feb 26, 2015 04:12 PM
andydunks
Jan 17, 2015 05:54 PM
DCMoose48
Apr 2, 2014 02:59 PM
