Sponsored by: Real Truck
Mildew smell from A/C?
Old Dec 7, 2004 | 08:53 AM
azzy522's Avatar
azzy522
Has anybody else experienced a moldy/ mildew smell from the air conditioner inside the truck cab?
I get a bad moldy/mildew smell when I turn on the Defrost or the A/C.
I have talked to my Ford Service department about this smell and they gave me a can of "Freeze Fresh" to spray into the air intake when I smell this odor. It claims to kill bacteria in the A/C unit. I have had to use this spray atleast once a week for several weeks now.
The service department says they can open up the A/C box and take a look but since the water does drain to the ground when the A/C is running they said that it is not a plugged drainage issue.
just wondering if anybody else has noticed this problem and what they have done or could do.
Thanks,
2004 F350 PSD CC DRW 4x4
Old Dec 7, 2004 | 09:06 AM
Big Orn's Avatar
Big Orn
It may be draining, but not completely. The drain hose could be dislocated (not fully seated at the bottom of the pan/box) and allowing moisture to remain inside.
Really, that's the only place moisture can build-up.
They need to look at the drainage system anyway...or else you'll always be spraying that junk in there.
Old Dec 7, 2004 | 09:29 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
What most people think of as "moldy" smelling is really corroded aluminum from the evaporator. But, a lot of times, it smells like a combination.
Guess what I've used for this a few times? Plain old Lysol sprayed into the air intake (for the A/C unit, not the motor!). Make sure the A/C is not on "MAX" (that will recirculate inside-cab air), and spray into the air intake in front of the windshield (I think it's right there on the SD's, isn't it?).
Lysol will kill everything just as well as any other spray, I'd assume.... and it works! And comes in a few different scents now...
The other solution is to use the A/C from time to time. I notice it smells after not using it for a while, but after using it a few times, the smell goes away (which is that aluminum smell, it's not really a "mold" smell).
Anyway... was that enough rambling?
art k.
Old Dec 7, 2004 | 06:52 PM
RedTaurus94's Avatar
RedTaurus94
Yep...Lysol has worked for me also.........
Old Dec 7, 2004 | 07:01 PM
boxcar1974's Avatar
boxcar1974
azzy522, I read your signature and see you have a 2004. When my 03' was "new", I have 40K miles on it know, I had that smell a lot. Have not had that smell for a while. Guessing it is that new plastic smell from the ducts.
Old Dec 7, 2004 | 07:34 PM
azzy522's Avatar
azzy522
The service manager told me that it was just cause it was new and that smell would go away. However I hav 11K miles now and I took him for a ride on another issue and he said "WOW" I did not know it was that bad. That is when he gave me the can of "Freeze Fresh"
What would happen if I pured straight bleach down the air intake on the cowl? whould it smell like bleach for along time?
Has anybody ever had a dealer open up the A/C evaporator box? I can see it from under the truck but it looks like one of them jobs that can only be performed with the engine out of the way. I would not think that would be a good engineering idea for service to the evapoator.
Old Dec 7, 2004 | 09:46 PM
krewat's Avatar
krewat
I wouldn't use bleach - no telling what it will do to the rubber seals and things, bad gases from reactions, aluminum+bleach?
I notice that if I use my vehicles (all Fords) alot, the smell goes away. If I do not use them, the A/C smells like rotten aluminum ...
Old Dec 8, 2004 | 06:38 AM
Big Orn's Avatar
Big Orn
Not me, azzy.
Did you notice if the discharge hose was collapsed or crimped? Could you pull on it to see if it was seated all the way down?
I can't remember what the flange looks like from underneath, but it seems like you could tell if the "water" was coming exclusively out of the end of the hose or if, maybe, there was seepage where the hose connects to the box.
Just a suggestion.
Old Dec 8, 2004 | 07:37 AM
azzy522's Avatar
azzy522
When I was under the truck I could see where the water was dripping from on the bottom of the evaperator box but it was not comming out of a "discharge hose". It was just a hole in the bottom of the box. Is there supposed to be a discharge hose comming out of the box? How far is it supposed to hang down?
Old Dec 8, 2004 | 07:51 AM
Big Orn's Avatar
Big Orn
Hmmm... That may be another one of those innovative moves to save money...??? I have a '99 that has about a 4" long hose that is semi-closed on the bottom to prevent dirt, dust, mud and dabbers out.
You just have a hole in the box???? No short nipple or anything? Odd...
Old Dec 8, 2004 | 09:52 AM
michaelmueller's Avatar
michaelmueller
this may sound dumb, but I had the same problem and all I did was turn the control **** to the off position when the truck is not in use. It works. my.02
Sep 30, 2016 11:27 AM
street rodder
Apr 1, 2016 10:56 PM
bigcountry1009
Feb 7, 2016 01:32 PM
Pony Power
Nov 17, 2014 08:33 AM
mnutz
1997 - 2003 F150
Feb 18, 2013 04:48 PM
