10K-4.7K Mod.
Old Dec 12, 2004 | 06:02 PM
Robbgt's Avatar
Robbgt
right now i have a 10k w/ a switch.... i don't have gauges yet... would it be ok to swap it out for the 4.7K only if i use it occationally... like for 5-10 second burst every now and then?? or should i hold off?? thanks in advance!!
Old Dec 12, 2004 | 07:39 PM
RickyBR's Avatar
RickyBR
I was using my 4.7 at very short intervals but switched it back out for the 10. I didn't want to chance it. Turbos are way to expensive for me to take that kind of chance.
Old Dec 12, 2004 | 07:46 PM
Robbgt's Avatar
Robbgt
thanks... so is it deffinate that a small burst usage could raise the egt's to high
Old Dec 12, 2004 | 07:54 PM
RickyBR's Avatar
RickyBR
I don't think 1 or 2 seconds would max you out, but anything beyond that your g-force sensors might get hooked and not want to let up.
Old Dec 12, 2004 | 07:58 PM
Robbgt's Avatar
Robbgt
Haha!! good point i didn't think about that!! i guess i will wait till i get them gauges... thanks!!
Old Dec 12, 2004 | 08:54 PM
JD shot's Avatar
JD shot
10K no mod
Guys,
10k mod doesn't do anything but turn on the check engine light. Are any of you using this on a 2002 7.3 PSD?
Old Dec 12, 2004 | 09:29 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by JD shot
Guys,
It works for any year 7.3, you might have hooked it to the wrong wires or didn't make good contact or something like that.
Old Dec 12, 2004 | 09:35 PM
Robbgt's Avatar
Robbgt
yea cookie is right.... you eather installed them in the wrong way... or you didn't make good contacts... go back and fiddle around with it... i got lucky cause mine worked on the first try... also... how are you installing them? i would go through the purple gasket thing on the top and carefully slide the wires in... makes for much better contacts...imo...hope this helps!
Old Dec 12, 2004 | 09:46 PM
JD shot's Avatar
JD shot
Question
This is what I did. I thought I would try the basic setup to see how it worked then if I was happy with the results i was going to assemble with a variable resistor and switch in the cab..
I soldered a 5inch piece of wire to each end of the resistor and routed the wires into the connector as shown with the leads bent then reconnected. Tried several times with no luck.
I'll give it another try tomorrow. I just don't see how I wansn't making a connection seemed to be pretty secure
Old Dec 12, 2004 | 10:46 PM
RickyBR's Avatar
RickyBR
the directions that I went by said that if the check engine light does not cycle off then one wire is wrong.
caskillet
Oct 19, 2014 05:59 PM
884x4broncoII
Aug 18, 2009 03:51 PM
rebelchevy02
41
Jan 26, 2009 07:51 PM
ForMaz
1983 - 2012 Ranger & B-Series
Aug 21, 2005 02:52 PM
