10K-4.7K Mod.
Old Dec 6, 2004 | 08:49 PM
RickyBR's Avatar
RickyBR
10K-4.7K Mod.
I switched my 10K out to a 4.7K. HOLY CRAP. I don't use it a whole lot because I have to get my guages hooked up but for the little bit that I used it so far, WOW. I have a toggle switch mounted right next to mw 4 wheel drive switch, that makes it extremely handy. It totally amazes me at how much of a difference a little thing like that can make.
Old Dec 6, 2004 | 10:00 PM
jpm2591's Avatar
jpm2591
Could you tell me more about the 4.7 mod? Is it more performance then the 10k mod? Thank you!!!
Old Dec 6, 2004 | 10:06 PM
Kwikkordead's Avatar
Kwikkordead
I have a 5.6 installed with a microswitch mounted on the gear shift handle. When I need an extra burst of power, just floor it, hit the switch you're off!
Old Dec 6, 2004 | 10:11 PM
DaBigTow's Avatar
DaBigTow
I used a 10k potentiometer + a 4.7k resistor in series. Any time I run it past about 8k real resistance, I get SES & bucking under a heavy load. Other than that, it works well. I've also used on top of a SuperChips tuner, but have to turn it back to about 12k resistance or it bucks a lot. Haven't tried it with the Edge tuner yet, but will now that I have guages installed.
Old Dec 7, 2004 | 08:16 PM
RickyBR's Avatar
RickyBR
This is what I went off of but I hooked mine up to a toggle switch mounted next to my 4X4 switch. Some guys hook them up to their fuel pedal somehow but I like being able to turn mine on and off when I want.
C:\Documents and Settings\Ricky\My Documents\My eBooks\Ford Powerstroke 10k Mod.htm
Hey Kwik, can you take a picture of yours. I don't want to switch mine over but I would like to see how that looks on the shifter.
Old Dec 7, 2004 | 09:45 PM
Kwikkordead
It's ugly. It's an old microswitch that I salvaged off of a Vanagon throttle body. Does the job though. Right now it's pouring rain out and don't feel like going outside. I'll take it later and post it.
Old Dec 7, 2004 | 10:38 PM
Kwikkordead
Ok, here it is.
Old Dec 8, 2004 | 07:20 AM
RickyBR's Avatar
RickyBR
aah, it don't look that bad. The real nice thing is it's always right there at your finger tips.
Old Dec 11, 2004 | 07:44 AM
rirwin's Avatar
rirwin
Are we talking about the little 99 cent resistor at Radio Shack, or is there a different one for this app.?
Old Dec 11, 2004 | 08:11 AM
RickyBR's Avatar
RickyBR
that would be it. .99 cents for a pack of 5.
Old Dec 11, 2004 | 09:02 AM
rirwin's Avatar
rirwin
Thank you much!
Old Dec 11, 2004 | 12:26 PM
belz's Avatar
belz
How dangerous would it be to have it hooked up to a momentary switch for occasional use. I run the 10k mod and I know I can add another resistor with a momentary switch for the occassional boost, BUT I dont have any gauges. Could I still do it, or should I stay away until I get some gauges?? I really want the gauges, but its hard for me to get the money for them, but those resistors came in a 5 pack so I got a couple layin around.
Old Dec 11, 2004 | 02:11 PM
RickyBR's Avatar
RickyBR
from what I've read on here, don't run no more than a 10K without guages. After the guages, nock your socks off.
Old Dec 11, 2004 | 02:35 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I JUST tried mine out. I've been building it for the last 2 days (spare time) and all I can say is that it's phenomenal the low-end increase. I just got back from town to try it out and it's a world of difference.
I think that I may make a couple of them and try to sell 'em. Here's what I did with mine:
4.7K ohm resistor mounted in series with a 0-10K ohm potentiometer. Toggle switch mounted in series with signal wire (red/orange stripe) off of idle position switch on accelerator. Relay to control resistor circuit. Light to indicate relay on/off. Mounted it all in a Ford relay box off of Taurus and put it in the cubby-hole below and to the right of the steering column. Found best results/driveability at 9.25K ohms. The way the system works is:
Idle at stoplight: no interference with idle quality
Take-off: light comes on indicating unit running parallel with ICP sensor
With the toggle switch off, there is NO ICP bypass anytime
Cost: $6.35 for dramatically improved stoplight-to-stoplight low-end torque.
Thanks for the tip!!! See wiring diagram in gallery.
Cody
Old Dec 12, 2004 | 05:42 PM
belz's Avatar
belz
Hey Cody, I just hooked mine up the way u have it except instead of the POT, i just have the 10k resistor. Cant wait to drive it. It idles normal finally. One day when I get my gauges, I'll thro out the 10k for a 4.7k.
