Code 63
Old Dec 6, 2004 | 02:45 PM
Rubbersoul's Avatar
Rubbersoul
Code 63
HI everyone
I have a 89 e150 efi 4.9, I'm getting a code 63 throttle position (TP) circuit fault, below minimum voltage.
Is this the throttle positon sensor ? I changed it back in 06/21/04 and it didnt take the code away, I did clear all codes.
or is it something else
Thanks for your help
Old Dec 7, 2004 | 08:57 PM
Mustang 5.0's Avatar
Mustang 5.0
yep. did you set the voltage for .9 volts?
Old Dec 8, 2004 | 11:20 AM
Rubbersoul's Avatar
Rubbersoul
Thx for the reply mustang, I put a new one in and the code is gone.
btw...how do you set it for .9 ?
another prob
code 21,24.....cooling temp sensor, and intake air charge, changed them both in april, could they both be gone again ?
or could it be a wiring prob ?
again thx for the reply
Old Dec 8, 2004 | 05:02 PM
Mustang 5.0
key on, back probe the wires with a digital multimeter. loosen the screws and adjust the tps for the reading.
check for 5 volts first.
BTW everyone, the book by Probst on EFI systems and sensors is worth the purchase for troubleshooting.
Old Dec 8, 2004 | 07:23 PM
Rubbersoul's Avatar
Rubbersoul
thx mustang sorry to be a pest, I'm new at FI.
I'll try that.
I also just got a code 51 - ECT sensor out of range indicated/circuit open.
I just changed the sensor this april so would this be the circuit itself ?
thx for all your help
Old Dec 10, 2004 | 02:51 PM
Rubbersoul's Avatar
Rubbersoul
Mustang
tried it and nothing, got 4.9 volts, loosened the bolts, the ones that hold it onto the TB, no change.
I take it I did something wrong ?
john
1986OhioF150
Jan 28, 2015 08:58 PM
kstones63
13
Jun 5, 2014 08:04 PM
Illbethejudge
Apr 10, 2014 04:17 AM
kingford72
Oct 22, 2012 06:32 PM
Diesel_Dummy _
Mar 3, 2003 08:06 PM
