trouble code 98
Old Nov 7, 2005 | 09:21 PM
kingford72's Avatar
kingford72
Unhappy trouble code 98
I've been having trouble with my 89 f-350 with a 351w, c6 2wd its running rough, surging idle, stalling the check engine light is on I got 2 codes out of the computer 63 which is a throttle position code and a 98 which is a hard fault in the eec system. the 63 comes on during KOEO tests and running tests the 98 comes on only during running tests. the throttle position sensor checks out fine 5 volts reference from ecm .97 volts at idle 4.97 volts at full throttle. Ive checked power and ground terminals at the 60 pin harness and that checked out and went over the entire engine looking for bad vacume hoses and leaks. I just wanted to see if anybody had any ideas or have had the problem before. I have a manual I,ve been on other websites but nobody explains code 98.
Old Nov 8, 2005 | 06:25 AM
scjfox's Avatar
scjfox
Ill do some research for ya today
Old Nov 8, 2005 | 06:28 AM
chmath's Avatar
chmath
Code 98 = Electronic pressure control driver open in EEC (E4OD).
Old Oct 22, 2012 | 06:25 PM
It's a Ford boi's Avatar
It's a Ford boi
weird i have the same two codes...what did you do to fix it?
Old Oct 22, 2012 | 06:32 PM
White 97 xlt's Avatar
White 97 xlt
Did you by any chance notice this thread is 7 years old, don't hold your breath for an answer!!!
Coresair
33
Jun 22, 2016 06:00 AM
DLeach4512
3.7, 3.5 and 3.0 Duratec V6
May 24, 2016 08:46 PM
azielenski
Mar 6, 2016 10:53 PM
Elisvk
Jun 17, 2014 09:19 AM
fjcsmc
1983 - 2012 Ranger & B-Series
Jun 6, 2010 08:23 PM
