2005 4x4
Old Dec 5, 2004 | 03:50 PM
critnour's Avatar
critnour
Unhappy 2005 4x4
Stuck in low range 4x4, probably a relay, anyone encounter this?
Old Dec 5, 2004 | 04:10 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
https://www.ford-trucks.com/forums/s...d.php?t=303583
Enjoy FTE
I have not read nor heard of this...hang around maybe another member has.
Old Dec 5, 2004 | 08:23 PM
tn mac's Avatar
tn mac
DID you try backing upu after you switched out of lo range, also the only time you really need low is if you are pulling something very heavy. high will do about 90% of off roading needs. unless you have large tires and did not regear to comp for the tires.
Old Dec 5, 2004 | 08:48 PM
stanphil's Avatar
stanphil
My 05 gets stuck all the time. switch it back to low, drive forward a few feet then go back to neutral & shift to 4H, if it transfers out of low, then move it on to 2H. You can also go to neutral while still rolling at almost a dead crawl and shift to 4H. sometimes this works.. Wish I had got the manual transfer case..
Old Dec 6, 2004 | 06:08 AM
Frobozz's Avatar
Frobozz
To get out of 4 low with the ESOF, you *must* be in neutral and have your foot on the brake. Switch the button and wait a few seconds and out it will come. If you are in gear, or are rolling without your foot on the brake, it won't happen. (This is in the owner's manual, by the way.)
Duncan
Old Dec 6, 2004 | 07:41 AM
kw5413's Avatar
kw5413
Sometimes my local carwash guys like to be funny and switch truck into 4 low.
Nothing like cranking those high RPMs excellerating into traffic (or trying to anyway). Then have to get off the street to get her out of 4 low.
Old Dec 6, 2004 | 08:26 AM
Frobozz's Avatar
Frobozz
If I'm ever in a situation where I think there's some increased chance of the truck being stolen, I leave it in 4LO. Given how hard it is to get it out of 4LO (as evidenced by this question popping up here every 2 days in wintertime!) I figure the thieves will give up trying to run away with my truck at 7MPH. I'd be able to catch up with them on foot!
Duncan
Old Dec 6, 2004 | 09:00 AM
deacjrt's Avatar
deacjrt
Duncan
This is funny, and smart. I like and might do the same.
Old Dec 6, 2004 | 11:35 AM
IB Tim's Avatar
IB Tim
Duncan
That is great
Old Dec 6, 2004 | 01:24 PM
waynerb's Avatar
waynerb
With dogs and fiream in tow.
Old Dec 6, 2004 | 10:21 PM
bdjupiter's Avatar
bdjupiter
Too funny, I guess you can just chase the screaming sound! Now just hope for everyone involved your not in your undies when they decide to make a "high speed get away"
Old Dec 7, 2004 | 12:22 PM
Customz's Avatar
Customz
My 04 4x4 got stuck in 4Lo. It wouldn't shift to 4Hi or 2wd. Had to get it towed to Ford. Turns out there was moisture in the defective relays. Wish I had the manual transfer case now.
Old Dec 7, 2004 | 12:58 PM
kw5413's Avatar
kw5413
My last 3 trucks (all Ford of course) all had auto hubs...never had any issues.
Old Dec 7, 2004 | 01:09 PM
NinjaRacer's Avatar
NinjaRacer
Duncan
Now THAT'S a good idea.
4x4x4x4
Jan 13, 2003 10:35 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
4x4x4x4
Dec 1, 2002 03:02 PM
4x4x4x4
Modular V10 (6.8l)
Nov 5, 2002 01:53 PM
4x4x4x4
Aug 13, 2002 09:43 PM
