Get Back Into Shape
Old Dec 3, 2004 | 08:42 PM
Rodney F-100's Avatar
Rodney F-100
Get Back Into Shape
OK, I have a 1960 233 inline 6 on a truck I just towed back from north, I changed... plug wires, condensor, points, dist cap, and the round thing that has the wire going to the dist cap middle. It has a slight tick and it has quite a bit of smoke coming out of the oil breather,,,(its negotible on whats a lot of smoke, any, is too much for me.) What is the best steps to go to start to get this engine healthy.
Old Dec 3, 2004 | 09:35 PM
85e150's Avatar
85e150
Burning any oil? Your breather smoke is blow-by. Any worn engine is going to have that. You can "tidy" it up if you install a pvc set up. Make sure you set it up with a proper PCV so you don't suck oil.
Or you can do a ring and bearing job, and have a smaller amount of smoke.
Old Dec 3, 2004 | 10:00 PM
Samsonitesamsonite's Avatar
Samsonitesamsonite
ticking check your lifters... that round thing was your coil... it may be worn but that engine should last for quite a while
Old Dec 4, 2004 | 06:33 AM
Rodney F-100
85e150six4mtod, What do I need to do to set it up with a pvc?
Old Dec 4, 2004 | 09:13 AM
sixpack2639's Avatar
sixpack2639
Proper PCV valve for application, A constant vacuume source (preferably from the baseplate of the carb), and a hole in the valve cover to place the PCV valve in. Oh, you'll also need a length of vacuume line to connect the PCV valve to the port on the carb and a rubber grommet in the valve cover so the PCV valve is sealed and not just hanging around. Hope that helps, Carl
Old Dec 4, 2004 | 04:36 PM
Rodney F-100
Thanks,I will check into it, just put a new breather cap on her today and that seemed to help a little.
clrose99
Apr 12, 2020 11:17 AM
1966TANK250
Jun 18, 2011 09:09 AM
Cowboy34
Feb 26, 2009 07:03 AM
Nod
Jan 12, 2003 05:23 AM
