Rebuilding the head
Old Dec 10, 2004 | 06:45 PM
  #31
DT 466Man's Avatar
DT 466Man
Well i thought an engine should use no coolant.
My dad told me it might need a head gasket so thats where i based my theory from.
It might not though.
Could the valve seals really cause it to use that much oil?
I just wonder how much oil those cars that smoke just cruising down the road use?(lol)
Old Dec 11, 2004 | 09:21 AM
  #32
snyiper's Avatar
snyiper
Do you fill the Rad to the top or do you use the puke tank (remote overflow)?
Based on what you are saying I would get the cooling system pressure tested see if the head is leaking as well as look at the plugs that can also tell you about a head gasket problem. I think the only thing you may need to get you till summer would be valve seals but if it runs well let it go till you rebuild it in a few months.
Glenn
Old Dec 11, 2004 | 10:41 AM
  #33
DT 466Man's Avatar
DT 466Man
all of the plugs are a light brown like they are supposed to be. I do top off the overflow tank. I can see where it is moist around the cylinder head bolt closest to the front of the truck on the carb side.
Old Dec 11, 2004 | 08:03 PM
  #34
kotzy's Avatar
kotzy
It may be leaking around the threads of that bolt, take it out and put teflon sealer or
Aviation Permatex (#3 on the threads and reinstall it) torque it to specs. You'll have to be quick about it or you will loose antifreeze, might be wise to get a spare head bolt
as you should clean the threads before reinstalling it.
train2
60
Oct 15, 2014 07:33 PM
pete60hill
Jun 29, 2014 08:16 PM
RangerDude17
General Automotive Discussion
Jun 24, 2014 12:40 PM
Xwarrior86
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 21, 2007 07:32 PM
96eddie5.8
1978 - 1996 Big Bronco
Feb 26, 2007 07:31 AM
