acceleration
Old Dec 1, 2004 | 07:22 PM
dieselstroke's Avatar
dieselstroke
Question acceleration
our 99+ trucks fly by wire, but why is it some drive easier than others?
Mine feels like for the position of the accelerator pedal it should be
easier to keep speed, but ya gotta keep on putting the pedal down,
and down. Is there a throttle position senser in the pedal assembly that
can go kinda bad but still work? Truck has fair power, but it seems like it
takes a lot of throttle.
Old Dec 1, 2004 | 08:34 PM
444dieselrod's Avatar
444dieselrod
Are you meaning you have to push the throttle alot to get it to come off idle???
there is a mod called power pedal believe that is the name. If you look at the throttle pedal you will see a little micro switch attached to it, and you can hear it click when you push the pedal down. Bend that little tap so that you hardly have to move the pedal to get a throttle response, but make sure you still hear it click, that micro switch controls the idle verification circuit. mine used to jump right up to 1500 from idle before i did this.
or it could be you throttle position sensor going bad, which requires you to replace the whole pedal asembly.
Diesel rod
Old Dec 2, 2004 | 04:18 PM
dieselstroke
no, just when you are accelerating from about, say 45-50 up to 70. So I can try
to bend the micro switch to get a little better throttle response?
Old Dec 2, 2004 | 04:24 PM
Domino'sDiesel's Avatar
Domino'sDiesel
You don't bend the switch itself but metal tab that releases it.
Old Dec 2, 2004 | 04:28 PM
dieselstroke
hmm, which way do i bend it? and how far in fractions of an inch, 1/8'' 3/16'' ?
Old Dec 2, 2004 | 05:09 PM
Domino'sDiesel
Bend it away from the switch. Do small increments to you find your desired pedal response.
Old Dec 2, 2004 | 05:13 PM
dieselstroke
i think I saw the tab up in there its kinda shiny, felt real thin and it was like 3/16'' wide
by maybe 1/2'' or 5/8'' long, is this it? Now the switch is behind it? So I would need to
bend the tab towards the firewall?
Old Dec 2, 2004 | 08:39 PM
Domino'sDiesel
It's the tab right off the "go" pedal (left side) about 1/2" by 1/2" bend it away from the switch toward you.
Old Dec 2, 2004 | 08:42 PM
dieselstroke
ok I'll give her a try after work tomorrey. this will work on a 99 tho right?
Old Dec 2, 2004 | 08:44 PM
Domino'sDiesel
I believe so. If you have problems I'll try to post pics of it tomorrow.
nickt916
15
Nov 30, 2013 05:15 AM
MTalley
13
Mar 5, 2013 12:31 PM
PrinceValium
2009 - 2014 F150
Dec 5, 2012 07:49 PM
Realgun
1997 - 2003 F150
Sep 18, 2004 02:33 AM
