Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Demagnetize
Old Dec 1, 2004 | 09:15 AM
mark a.'s Avatar
mark a.
Demagnetize
Anybody know of a home remedy for demagnetizing little things ? screw drivers, wrenches, etc.
Old Dec 1, 2004 | 11:24 AM
Jag Red 54's Avatar
Jag Red 54
I have a "magnetizer" from Craftsman. It is basically two magnets with opposite poles held together by a rubberband. To magnetize a screwdriver, I put it in the hole in the middle. To demagnatize, I slide it along the outside. So maybe by sliding your item along a magnet in various directions, the magnetic charge will be removed. ?? Good luck, John
PS: This thing was cheap to buy. $2-3??
Old Dec 2, 2004 | 04:49 AM
Torque1st's Avatar
Torque1st
Posting Legend
Do you have an old VCR tape demagnetizer? Maybe that would work???
Old Dec 2, 2004 | 08:43 AM
5_labsownus's Avatar
5_labsownus
Find a watch shop that does repairs on site and they should have a demagnatizer to demag. watches! If you were near by I have one!
Old Dec 5, 2004 | 08:10 PM
jbullfrog's Avatar
jbullfrog
I actually learned something in college!
To demagnatize something drop it on a concrete floor. The shock will realign the ionic structure and demagnatize the object. This does work, as I use magnetic trays and have to demagnatize wrenches and bolts often.
Old Dec 6, 2004 | 12:13 AM
rocketroy's Avatar
rocketroy
demagnatization!
to de magnatize somthing strike it with both leads off a battry charger or a 9v battery, this will randomise its atoms,i think thats what he called it,
where as when you touch it on a magnat you align the atoms, hey school was 20 years ago, but it works !
Old Dec 9, 2004 | 04:31 AM
angus's Avatar
angus
Or wind a coil of insulated wire, as many turns as you can manage, 18 gauge or so, around a tube or something insulated and non-metallic. This is just one wire, not like 2 or 3 wires in an extension cord. Break one wire in an old extension cord and splice this coil into it. Plug something that pulls a reasonable current into the extension cord, maybe a heater or a couple hundred watts of light bulbs. Now, slowly push the magnetized tool into the coil, leave it a while, (seconds, not hours), then pull it out slowly. And unplug all this stuff. The alternating magnetic field should neutralize the magnetism.
You can use the same coil to magnetize stuff; just put the tool into the coil, then momentarily touch the leads across a DC source like a car battery. Don't do this with a battery that's being or was recently charged, or the sparks might ignite hydrogen gas and ruin your day... use jumper cables as an extension or something like that.
I know that 10 turns or so is enough to magnetize; demagnetizing could take more. Try it and see.
Old Dec 9, 2004 | 10:34 PM
midlf's Avatar
midlf
Tape demagnitizer
A tape eraser/demagnitizer will work just fine. I use mine often as my tools, especially screw drivers, get magnatised often. There are times when I want a tool magnatized and a DC shot on a coil or stroking across a magnet will set the magnatism and the tape eraser takes it off.
Old Dec 10, 2004 | 08:43 AM
jamesemery728's Avatar
jamesemery728
Harbor Freight sells an inexpensive one that should work fine. It's just magnets encased in a plastic frame. All of their junk is returnable if it does not work. Your next best option is to find a local watch repairman like some of the other posts have suggested. Any of them are only going to work on small items, nothing very large in diameter.
Old Dec 12, 2004 | 10:41 PM
nick88f150's Avatar
nick88f150
i just always take and strike the magnetized metal on another peice of metal and it always works for me.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
