360 to 302 help newbie!
Old Nov 30, 2004 | 08:59 AM
nelson3's Avatar
nelson3
got a 70 f100 ranger with 360 want to go to 302 i dont want to cut or drill nothing.truck is original all but motor and dont want to fabricate.what year 302 doesnt matter long as fit.what will i have to change it has a automatic tran.
Old Nov 30, 2004 | 09:53 AM
Mike G's Avatar
Mike G
First off, let me say welcome aboard!
Secondly, since you do not want to fab anything, find a donor truck with a 302 or 300 I6 and grab the engine towers, the ones that bolt the motor to the frame. These trucks come with several holes in the frame and several motors were options, just need the right combo for your application. One thing to consider, the trans behind your 360 will not bolt to a 302, so you may want to grab the tranny crossmember and drive line from the same donor vehicle.
Personally, I would just rebuild and keep the 360, about the same amount of work and cost as a swap, but that's my opinion...
--Mike
Old Nov 30, 2004 | 10:31 AM
312's Avatar
312
any 302 351 frame mounts from 67 to 79 will work.not 300.everything is a drop in with right parts.if your trans is stnd,all you need is bell.you will of course need 302 truck engine mounts as well.
Old Nov 30, 2004 | 11:04 AM
RR4E's Avatar
RR4E
It'd be a lot easier to change up to a 390 (direct bolt in) and retain the venerable, and ever so reliable FE block that you already have. I can't imagine wanting to step down in the tourque and horsepower bands. Switching to the 302 will likely see a mileage drop, or at the very least, no improvement.
Old Nov 30, 2004 | 12:14 PM
mouse777's Avatar
mouse777
First welcome to a great site. Check the tech articles, click on engine. I'm in the process of the same swap with a 71. I went with the SEFI. Not a bad swap.
Old Nov 30, 2004 | 12:39 PM
nelson3's Avatar
nelson3
ok check this out thanks for the help.ive got sitting in my barn a 1976 ltd immaculate condition that was my wifes grannies its now mine i didnt want it but she did.but now since her grannies past she told me i could do what i wanted with it.it has a351m in it with 68,000 original miles on it.they say it want work in my 70. it runs like a greased top.what are my options.it probably uses more gas than the 360.im lost! ideas please!!
Old Nov 30, 2004 | 12:46 PM
nelson3's Avatar
nelson3
what about a 351m.....
out of a ltd with 68000 miles on it.what are my possibilities.original miles too!
Old Nov 30, 2004 | 05:41 PM
mouse777's Avatar
mouse777
I don't know about mileage but it will fit. I drive a 87 Crown Vic just like donor for my truck and I get 22 mpg mixed driving. I don't know for sure what my diff gears are, but gears are pretty easy to come by. My preferance is SEFI, but thats just me.
Old Nov 30, 2004 | 05:45 PM
312's Avatar
312
it will fit but if your worried about gas milage leave it be.
Old Nov 30, 2004 | 05:58 PM
4Cammer72's Avatar
4Cammer72
actually 312 the 300 I6 mounts will work, have used them 3 different times. just use the 302 motor mounts and move the towers to the back set of holes on the frame.
Old Dec 1, 2004 | 07:03 AM
jowilker's Avatar
jowilker
Bruce, Neither engine that you have referred to will bolt up to your tranny. Lucky you, You have mentioned all three of Fords engine bell families.
The FE 360/390 has a round top bell, The 300/302/351W/351C have a flat top bell with a 5 1/2" bolt spread, the 351M/429(never installed in a pickup)/460 use a flat top bell with about a 8" bolt spread.
Should you choose the 302 (big loss of power to the 360) you can use a AOD overdrive tranny, not available to the FE.
Personally I would not recommend the M for a truck. The pickup is much more of a box and even if you changed the rear gears too, you won't get the mpg that the car does.
A little more fat to chew on.
John
Vickadelphia
17
Dec 13, 2013 08:24 PM
AZ F250
Jul 29, 2011 08:48 AM
DeepRoots
Nov 2, 2009 02:09 PM
airbusflyboy
Sep 11, 2009 03:13 PM
shunderwunder
Mar 15, 2003 06:58 PM
