Oil Pressure problem, engine sputter
Old Nov 29, 2004 | 06:12 PM
tyguy81's Avatar
tyguy81
Ive got a 99 Ranger 3.0 automatic 2WD XLT all stock with 120k miles and ive got a weird problem i havent been able to find a solution for....ive been to pepboys and while they had it they didnt find a problem....just recently it got worse and dont feel like shelling out money on diagnostic fees if its just something i may be able to fix myself....heres the problem
it started about 2 months ago after i changed my oil in the drive way.....i had just switched 1 oil change before to a high mileage 10w30....well anyways chanegd my oil then proceeded to drive to work when my trucks oil gauge starting ocsillating up n down and even would sit on 0 for seconds at a time....and would only do this during idle or while coming to a stop....and at the same time my engine would sputter but no die....i tried to explain the peoplem to someone at an automotive parts store and he immediatly thought the worse...maybe a cracked piston ring or something(which this may still be the problem)...i then askin a friend who used to be a mechanic and he thought maybe it was a plugged up pcv valve so i changed that out..the problem got significantly better but was still there....would do it maybe once or twice a week i can feel the engine sputter slightly and the oil gauge would flicker maybe once or twice and i drove it like this for 2 months with no sign of it worsening....til today i just had my oil chanegd at WalMart with high mileage 10w30 and it started doin the same thing again....at about the same intensity as it was 2 months ago....does any1 have any idea what might be causing this?....i hope its not the cracked ring....i dont have money to pay for any expensive repairs at the moment
btw first post
would appreciate some help from the vast knowledge ive seen on these forums
thanks
Old Nov 29, 2004 | 10:51 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
It only happens at closed throttle? I'm thinking it might be an idle problem, as opposed to a oil pressure problem. If the engine RPMs are going too low, it could be causing the oil pressure to drop low enough to affect the gauge (which BTW is a "dummy gauge" in that it will only display one reading (middle) after the pressure has reached a certain level).
To complicate things, the oil pressure sender on the 3.0L can also go bad, causing the gauge to get all out of whack. I've seen a few posts describing that happening.
So you might consider an idle problem (IAC valve maybe?) as well as a sensor problem.
Old Nov 30, 2004 | 07:05 AM
tyguy81's Avatar
tyguy81
i doubt it simply the oil pressure sender because of the engine stutter....ill look into the other things thanks
Old Nov 30, 2004 | 08:16 AM
tyguy81's Avatar
tyguy81
oh howd i forget this.....another part of the problem.....theres air hissing from the dipstick location.....that may help the diagnosis
Old Aug 10, 2005 | 09:57 PM
exploranger's Avatar
exploranger
While a cracked ring would probably cause the rough idle and the hissing sound, so could a broken or loose vacuum line, and would be much easier to look for. good luck.
Old Aug 11, 2005 | 10:28 AM
tyguy81's Avatar
tyguy81
the issue was fixed a while ago.....it was a vacuum hose...have not had any problems since
sorry for not updating this post a while ago when it was fixed, i completely forgot about it lol
salem747
Jul 18, 2017 10:44 AM
crimson080
Jul 18, 2016 09:09 AM
NotURMailman
Jan 27, 2016 03:08 PM
85F350IDI
Sep 16, 2015 05:06 PM
Dezertracer66
16
Mar 2, 2010 07:02 PM
