My 7.3 won't start
My 7.3 won't start
My 1996 E350 7.3 powerstroke sputtered and would not start. Sputtered again, started and sputtered, ran for 20 sec. and quit. Now it just will not start.
What I've tried: Drained some fuel from tank to check for water, changed fuel filter, drained fuel filter body and refilled w/good fuel. Filled my HPOP reservoir and cranked, got 2 or 3 sputters. Then I rechecked the HPOP reservoir and have found it is low after just a few cranks. Filled it again,same thing, low again. After 3 or 4 repeats of this effort, my oil in crankcase is now above the full mark ( was at the fullmark when I started all this). Temp outside is 40 deg. +/- and I have used the block/water heater just in case. Truck is a "sold as incomplete" motorhome chassis with 16 ft. box added w/econoline cab. Fuse panel has 18 fuses (except no #13 fuse)205K miles, ran fine when last used a month ago.
I would appreciate any suggestions.
Welcome to FTE.
You overfilled the crank case by topping off the HPOP reservoir a few times? How much oil did you put in there? You do know you cannot fill it all the way up, right? How low does the oil in the reservoir get? If it pumps itself empty, then I'd say you've got an IPR issue, LPOP issue, or cracked pick up tube. If it's only an inch low after cranking, we need to go a different direction.
There's a standpipe inside there that drains excess oil back down into the crank case as you pour it in. If you pour slow enough, you could dump 15 quarts in there. The full level is around 3/4" - 1" from the top, so it sounds like the oil level in there really isn't dropping. LPOP is low pressure oil pump and IPR is injector pressure regulator.
Does your WTS (wait to start) light come on with the key? When you're cranking, is there any smoke coming out of the tail pipe? If you haven't driven in a month I'm guessing you have another vehicle. Have you tried to jump start it? Just because the motor spins doesn't mean you have enough power to operate the glow plugs and fire the injectors.
Because if there's no smoke at all coming out of the tail pipe while cranking, then that means the injectors are not firing. Could be the IDM is not commanding the injectors to fire due to low voltage or some other issue, could be low engine oil or lack of fuel. Could also be an electrical or CPS issue. Smoke coming out the tail pipe eliminates a lot of things.
Chis , from the diagrams I have seen, both stand pipes are "oil in", how is the oil getting to the c case from there (without the IPR dumping)?
