You need to figure out if you're losing fuel or spark. You said it had spark, so it should fire when you spray carb cleaner in it. That would confirm that the injectors are not firing. If none of them are firing, then it has to be the injector power someway or another and new injectors aren't going to work either. Check the red wire to the injectors when the car is cold (i.e. able to run). Check again when the car has stopped running, and won't start at all. See if the 12 volts is gone...
finally got my b2 running turned out to be quite alot of stuff i didn't think it was
pcm was shot it was burned inside. module was fine distributor was fine fuel pressure turned out good but oil pressure was nonexistant so i changed rear main oil seal and oil pump screen etc.. did oil change 20w-50 and one sae40 for the lifter help i'm going to redo my free floating rockers i almost have a new truck
both pumps new new tank 36gallon high capacityfuel filter ,fpr,fuel rail,injectors.
all new ignition sutff, batt,alt,starter,cables, turned out to be oil and pcm the least thing i didn't expect and later fix all that did the timing boom truck runs fine finally
