1987 F150 fuel problems?
Old Dec 1, 2015 | 06:36 PM
snublifeFFSP's Avatar
snublifeFFSP
Hi I have a 1987 F150 V 8 302 EFI. The motor does not run right. It starts and runs fine when it is cold. Once it warms up, I have to keep it above 1000 rpm or it will die. Once I'm driving it runs really smooth. I changed out distributor cap and rotor, spark plugs and wires, ignition coil, in tank fuel pump, high pressure fuel pump, and changed the transmission fluid and filter and still no difference. Any help would be greatly appreciated. This is my only vehicle
Old Dec 22, 2015 | 07:00 PM
Jlford150's Avatar
Jlford150
It is definitely a vacuum leak. Probably around the IAC valve or the ERG. Look for loose hoses and a hissing sound.
HartleyJ
General Automotive Discussion
Feb 28, 2016 06:40 AM
GEnglish
Jan 22, 2011 10:17 AM
keating
Jun 8, 2009 07:32 AM
t0ny78
Mar 8, 2004 08:53 PM
1 Big Mike
19
Nov 2, 2002 10:34 PM
