DOME LIGHT
Old Jan 23, 2002 | 07:56 AM
MACS RANGER's Avatar
MACS RANGER
DOME LIGHT
HI everyone i,m new here.
I have a 1997 Ranger XLT. My dome light stays on, so I hade to pull the fuse so as not to kill the battery. I don,t know if the problem is in the relay under the glove box or in the door switch. Does anyone know where the door switch is or how it works ? There is no plunger in the door jam. Any help is appreciated.
Thanks in advance
Paul
Old Jan 23, 2002 | 03:54 PM
DCaedo's Avatar
DCaedo
DOME LIGHT
The dome light switch part of the the door lock located inside the rear of the door. It controls the dome light indirectly through the GEM module behind the radio (in the dash). You might get the door chime too sometimes.
The good news is a little WD40 or CRC or whatever in the door latch fixes you right up. Haven't had to redo for 40K miles so far.
Hope this helps.
Old Jan 25, 2002 | 08:27 AM
MACS RANGER
DOME LIGHT
Thanks DCaedo the WD40 trick was the cure. I sprayer the lock, closed the door a half doven times and everything is fine now.
Thanks again
Paul
Old Jan 28, 2002 | 11:34 AM
tcgrafx's Avatar
tcgrafx
DOME LIGHT
I've been having this same problem with my '97 STX... I also get an intermittent "DOOR AJAR" light on the dash. I was hoping the WD-40 trick would take care of it.
Thanks for the tip!
Old Jan 28, 2002 | 02:10 PM
red ranger's Avatar
red ranger
DOME LIGHT
Critterhunter
38
May 26, 2017 01:05 PM
phillyken
Apr 2, 2016 09:44 PM
pepito113
2009 - 2014 F150
13
Jan 31, 2014 03:47 PM
SDNick
Electrical Systems/Wiring
Sep 13, 2003 01:13 PM
Sedric
Jan 5, 2003 11:06 PM
