Dome Light Wire
Old Sep 10, 2003 | 12:30 PM
SDNick's Avatar
SDNick
Dome Light Wire
Hi All,
I have a 2003 350 CC and want to install a switch to kill the dome lights when the doors are open. Does anyone know of a single wire that I can tap into to kill both dome lights?
Thanks,
Nick
Old Sep 10, 2003 | 12:40 PM
Mil1ion's Avatar
Mil1ion
Dome Light Wire
I'm not sure if this topic has had an results in here.
I know this topic has been posted several times though.
Maybe through previous pages for an identical thread
Access to previous pages is at the bottom of this page
Welcome to FTE !
Old Sep 11, 2003 | 07:43 AM
SDNick's Avatar
SDNick
Dome Light Wire
Thanks Mil1ion,
I have searched all of the news groups, but haven't really found an definite answer to this issue. Any idea if Ford is going to fix this? My dealer said that Ford claims the instructions for the dome light switch in the manual is a mis-print. I don't quite beleive it.
Thanks,
Nick
Old Sep 12, 2003 | 10:28 AM
WORKFORD's Avatar
WORKFORD
Dome Light Wire
Turn off the dome lamps!!!
I found a way to turn off the dome lamp and bed light on the back. I had the rear seat taken out which helps. I took off the headliner on the drivers side so I could see the wires coming off the light. They run down the drivers side rear corner. If you go to the floor in the corner (drivers side rear corner of the cab) you will find some wires. I tested them with a probe to see what was hot. There were 3 hot wires there. I believe the proper wire is black with a green stripe. I cut the wire, spliced a longer piece to each end I cut and ran those up to the metal piece right below the rear window. There are already some holes in the metal there which facilitate putting the switch in. I put a switch in and put each end of the wire I cut on opposite sides of the switch. Now I can turn off the dome light and the bed light (on the back of the cab). It works great. I work at night a lot and don't need the lights
Old Sep 13, 2003 | 01:13 PM
AegisSailor's Avatar
AegisSailor
Dome Light Wire
Manual says it's a Black/Light Blue wire going from the dome light to the GEM attached to the fuse panel under the dash.
Jhndere
Electrical Systems/Wiring
Feb 4, 2017 02:53 PM
mrstephs
Apr 16, 2016 08:13 AM
Doubleubar
Feb 24, 2016 06:33 AM
BLACKHAWK_1989
Jan 7, 2016 09:42 PM
MikeAubrey
Jun 1, 2006 09:09 PM
