Bronco II Ford Bronco II
Clutch Problem
Old Nov 25, 2004 | 09:11 PM
Bronco2Nic's Avatar
Bronco2Nic
Clutch Problem
I finally got my truck all back together and running but there still is one problem. My clutch dose't seem like it's releaseing fully. I can push the clutch all the way in and its hard to get into 1st-2nd-and reverse. All the other gears are fine. Sometimes when I push the clutch in there is a scraping sound. It isn't a constant sound though. The sound is also in relation to the RPM. If I rev the engine then the frequence increasses. If you can help me with this problem then that would be greatly appreceated. Thanks for any help.
Old Nov 28, 2004 | 11:13 AM
johnsteph515's Avatar
johnsteph515
sounds like it might be the slave try bleeding it first and if that doesn't help then it might be the slave, i have another slave for a 1985 bronco ii 4wd 2.8l 5 speed let me know ok. john goodall
XxWINxX94
Jun 21, 2011 05:46 PM
stephano
1983 - 2012 Ranger & B-Series
May 21, 2011 11:17 PM
1978fordf250
28
Jul 9, 2007 10:58 PM
Bronco2Nic
Bronco II
18
Apr 5, 2005 06:29 AM
Saoxcore2K5
Feb 2, 2005 10:43 AM
