'78 Clutch "clunk"
Old Jun 21, 2011 | 05:19 PM
XxWINxX94's Avatar
XxWINxX94
'78 Clutch "clunk"
Hey everyone,
My '78 Ranger Shortbox 4x4 clutch is kind of acting up. I have the 351m400 engine with a T18 trans in a 4 speed manual.
The clutch sticks up alot, and I really have to push it down to be able to shift, but that is not the problem. The first slight depression of the clutch is harder and results in a "clunk" sound, and after that, it pushes down fine. This happens 90% of the time when I depress the clutch.
My truck shifts fine and this problem is not causing any problems as of right now, but I'm worried so nothing bad happens on the road or unexpectedly.
I got under the truck and seemed to see that the release bar assembly seems to be bent, possibly from a bent or damaged bushing(s) or lugs on the release bracket, but I'm not sure.
I really did not want to spend the $ for a new clutch or the time for putting it in.
Is there any clutch experts out there who may know/have experienced this problem? I guess I am looking for a fix for it or any other information.
I can post a picture of the clutch assembly under the truck if needed.
Thanks for your help!
Old Jun 21, 2011 | 05:46 PM
bigdaddys76's Avatar
bigdaddys76
As I recall there are two white plastic bushings in the bell crank assembly that are wearable items so to say and when they wear it allows that assembly to **** sideways thus giving clutch chatter. One bushing is on the engine block side and the other on the frame side real cheap at the stealership and easy to put in. This might be a starting point for you.
76f1390
1983 - 2012 Ranger & B-Series
Dec 3, 2007 08:23 AM
kerry2
Jul 27, 2006 07:02 PM
JR270
Jan 3, 2005 08:40 AM
wrenchturner
Apr 26, 2004 05:04 PM
