missing egr?
Old Jan 8, 2002 | 10:50 PM
hms365's Avatar
hms365
missing egr?
92 ranger 3.0L - Is there any chance this would not have an EGR? I thought I knew what an EGR looks like, I've got the Chilton book (with picture) sitting right here, and no EGR. There is a plate on the intake that looks original and factory installed where the picture shows it. Flat spot on the exhaust where the picture shows it, but no hole. HELP!!!:-X11
Old Jan 9, 2002 | 04:13 PM
RangerBill's Avatar
RangerBill
missing egr?
No EGR on your application!!!
Old Feb 6, 2002 | 07:31 AM
larmanda's Avatar
larmanda
missing egr?
Hi, That is exactly what I hve found. I asked at FORD dealer and best he could saywas follow the vaccuum line back behind the distributor. Boy is tht a tight spot.so am awaiting furthur HELP:-X11
Old Feb 6, 2002 | 07:34 AM
larmanda's Avatar
larmanda
missing egr?
If no EGR how do it pass emission test.for NOX.
Old Feb 6, 2002 | 08:16 PM
hms365's Avatar
hms365
missing egr?
It never had a problem passing emissions. Now I wonder what is different on that engine design that it doesn't need one.
PS No lines from the back of the distributor are plugged or missing - it had to come from the factory that way.
Old Feb 7, 2002 | 09:22 AM
larmanda's Avatar
larmanda
missing egr?
I called FORD with VIN and my 93 Ranger 3.0 has no EGR.Now if I could find outhow it controls NOX so I can fix emission problem
Old Feb 7, 2002 | 01:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
missing egr?
It controls NOx by basic engine design the produce low NOx, and a catalytic converter to remove NOx from the exhaust.
If you are failing NOx, you are running too lean, have the spark advanced too much, or the catalyst isn't working.
Mark
Old Feb 7, 2002 | 06:29 PM
destiny88's Avatar
destiny88
missing egr?
JaySVX
Jan 28, 2012 10:17 PM
cypherja
1997 - 2003 F150
Sep 26, 2002 07:19 AM
doug
Aug 11, 1999 10:45 PM
