95 Ranger 4.0 EECV getting codes
Old Feb 9, 2002 | 04:26 PM
rdgerunrpa's Avatar
rdgerunrpa
Post 95 Ranger 4.0 EECV getting codes
My 4.0 Ranger has been stalling when at idle . The EGR valve was rusted and had a small hole in it , I thought it was this giving me troubles . I replaced it . She still stalls at idle ( has plenty of power and runs fine . ) I just replaced the plugs and wires and filters . She still stalls at idle ....... She'll idle fine ( nice and smooth ) for a minute or two , than all of a sudden , the tach dips down and she stalls . I don't know if this is related , but after a long run on the highway , after I get off and I'm traveling some county roads , between 40 and 50 mph , right when the trans shifts , the whole truck will pulse or buck . Seems like some sort of trans problem . The check engine light comes on . Is there an inexpensive way I can read the check engine codes like on an EECIV . Where all you have to do is put a jumper across the 2 terminals and the check engine light will flash the codes ? If so , where is the terminal located where I do this ? I'm trying to avoid taking it to the dealer , as money is alittle tight right now !! Any help or information would be greatly appreciated .. Thanks .. Rick in PA
Old Feb 10, 2002 | 01:19 PM
destiny88's Avatar
destiny88
95 is around the OBDII years. If it has OBDII you will need to scan it. If you are not sure if it is OBDII, look for a plug within reach from the drivers seat. On fords they are usually below the dash, this connector will be in the shape of a pyramid.
Old Feb 13, 2002 | 07:49 AM
bandlow's Avatar
bandlow
1995 is a transition year. '95 Explorers are EECIV (OBD-I) which can be read with the wire jumper and the MIL light or an analog voltmeter.
1995 Rangers are EECV (OBD-II) and need a code reader or scan tool.
I have heard of people having codes read at parts stores (AutoZone in particular) free of charge. I would check around.
Rich
Old Feb 13, 2002 | 08:38 AM
bazzman's Avatar
bazzman
tlk401
16
Apr 20, 2013 12:50 AM
brian931
Dec 29, 2010 05:31 AM
ptesmoke
Aug 21, 2008 12:56 AM
wolfehunter
Nov 20, 2003 11:52 AM
rdgerunrpa
Jun 4, 2002 09:12 PM
