FE cam bearing
Old Nov 23, 2004 | 09:26 PM
FoMoCo390's Avatar
FoMoCo390
FE cam bearing
I recently installed cam bearings in my FE block and I noticed that the number one cam bearing(front), in addition to having two oil holes and a groove connectiing them, also has a groove leading off the side of the bearing. What is this groove for ? I'm pretty sure I have it facing the right direction, since it's the only way I could install it with my cam bearing installation tool, but I'm not clear what the purpose of the groove is for. Anybody know ?
Thanks
Dan
Old Nov 23, 2004 | 09:35 PM
dinosaurfan's Avatar
dinosaurfan
oil grooves
I believe you are looking at the groove that supplies oil to the front face of the number one cam journal, it ( the cam ) pushes against the retaining plate, and needs some lube to protect it. DF, @ his Dad's house
Old Nov 23, 2004 | 10:20 PM
FoMoCo390's Avatar
FoMoCo390
Each of the cam bearings had lead on one side, making their installation more or less straight forward. However, if I was to install the #1 cam bearing with that groove facing out, the lead of the bearing would be on the wrong side. I have a driver type cam bearing tool and it aligns off the other bearing bores. So in order to install the cam bearing with the lead facing the right direction I would've had to have done it from the outside of the block, and therefore not been able to use the tool ?
Dan
maxoverdrive69
21
Mar 25, 2015 10:40 PM
abyars111
Mar 23, 2015 10:23 AM
hivoltj
Mar 1, 2013 05:03 PM
69supercj
Jan 19, 2011 12:25 AM
grandmas77f150
Dec 3, 2009 06:18 AM
