Got a 3 groove pulley for my pickup but I'm not sure of its origin. Its stamped DOOE-6312-?
This pulley is missing its IDengineeringnumber's suffix, but it's prolly the following, since I cannot find anything else w/a D0OE prefix.
D0OE-6312-C = Ford part number: D0OZ-6A312-B .. Triple Sheave Pulley-1970/72 Mustang/Cougar/Torino/Fairlane 351C / 1971/72 LTD 400.
I don't believe this pulley will bolt to your FE's harmonic balancer, as its bolt pattern is different.
hollygreenman: D0OE-6312-C is not a casting number. Casting numbers cannot be crossed referenced to Ford part numbers.
Casting numbers found on bare blocks, cylinder heads, intake/exhaust manifolds, trans cases, axle housings, steering boxes, I-beams.
Thanks guys, yea the suffix was missing, in fact the 2 on the 6312 was missing, must of been a bad stamp. Would this pulley also be for a Boss 351 and or a CJ?
D0OZ-6A312-B = 351C 2V/4V, except Boss & Cobra Jet.
