Doing repair & need help
Old Dec 2, 2004 | 09:51 AM
Hangfire's Avatar
Hangfire
Originally Posted by PLC7.3
Well guys the gentleman asking the question has a solid state system, on other forums it is strongly advised to retain the system in good working order. The system if working has been proven best time and time again. Mine has worked for 12 years with no problems. Did have some Autolite/Champion problems with GPs but SSC and Beru are one happy family.
Granted the older gp systems were very bad and burned up GPs when they stuck on. Doing the push button with them is strongly advised.
Do any of you have the exact way written up to do the push button in the Solid state system, if so please PM it to me as I would like to see it and keep it in my files....thanks
PLC7.3
How do you know if you have the older gp system or the solid state system?
I have a '92 7.3 F-250, should I convert to the push button system?
Thanks!
Old Dec 2, 2004 | 06:57 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The old style system was in the 86 and older diesels, in 87 they went to the new solid state system.
As far as should you change, that is personal preference.
I am in and out of my truck many times a day while working.
With the controller hooked up the glow plugs heat every time I start the truck even though it is at operating temp because I just turned it off 5 minutes ago. I do not like changing glow plugs on mine because it is a turbo motor, they are a pain to change.
So instead of heating them 50 times in one day, I use them once in the morning. That 50 times is now two months worth of glow plug cycles instead of one day. Since I control the glow plugs they heat less times in a year now than they did in a week with the controller working. Wonder why they last so much longer now.
Gundown64
23
Dec 31, 2011 10:04 AM
Gundown64
2004 - 2008 F150
Dec 23, 2011 06:32 PM
Knocker
18
Dec 15, 2011 09:15 AM
Chuck14
Electrical Systems/Wiring
Feb 23, 2009 04:41 PM
OfficerDangle
17
Jan 6, 2007 08:36 PM
