I have a major goof up. I bought a park/neutral switch for my E4OD a couple of weeks ago and some how I have wound up w/o any instructions. I have two problems now.
1) how to line up the switch. I'm assuming (I know shouldn't do that) that I'd line the groove with the N on the switch then put the shifter in neutral then bolt the thing on. That right or do I do something else?
2) The new switch requires a new connector and I have no way of knowing which way to wire it up. Luckily I kept the old connector on the wiring (but unluckily I tossed the old switch after I bought the new one) so I know the order I just need to know if the white w/ orange strip goes to the front or to the rear. Or the location of any other color wire.
