I have a major goof up. I bought a new park/neutral switch for my E4OD a few weeks ago and today when I went to put it on I discovered that the directions are missing! I have two major problems (three if you count the fact that I tossed the old switch).
1) how do I line up the switch? If I had to assume I put the gear shift in neutral and line the slot on the switch.
2) which wire goes where. Luckily I kept the old connector on the wiring harness so all the wires are in the correct order I just need to know if the white w/ orange strip wire goes toward front or rear.
