Offroad & 4x4
Np205
Old Nov 18, 2004 | 11:49 PM
f250rangerexplorer's Avatar
f250rangerexplorer
Np205
What is the low range gear ratio on the 205?
Old Nov 19, 2004 | 12:03 AM
ivanribic's Avatar
ivanribic
I believe it's 1:1.98.
Old Nov 19, 2004 | 12:14 AM
f250rangerexplorer
thanks Ivan. So with my 4.10 rear i should be about 6.08 in low, right? And what are the ratios in the C6. 1st & 2nd?
Old Nov 19, 2004 | 01:17 AM
highboy 74's Avatar
highboy 74
Speaking of that. Is there lower geared aftermarket gear sets for the NP205??? I believe the factory gears are 1.96:1.
Old Nov 19, 2004 | 01:48 AM
monsterbaby's Avatar
monsterbaby
No your final drive ratio would be 8.118 in top gear, and if you don't have a wide ratio gear set in the C6 first is 2.46:1, second 1.46:1
Highboy I read somewhere you can get a 4:1 gear set for the np 205 but someone else will have to chime who makes it, I know I read it in one of the off road rags when discussing rockcrawlers.
Old Nov 19, 2004 | 02:24 AM
ivanribic's Avatar
ivanribic
Nobody makes a low gear set for the 205 right now. LoMax keeps talking about it as do some others but it hasn't happened and I don't think it will any time soon. Your best bet would be a doubler with the 203 gearbox. Then you'd be at almost 4:1
Old Nov 19, 2004 | 02:21 PM
hoxiii's Avatar
hoxiii
There actually is a set of 3:1's out for the NP205, but right now it's only available for chevy cases. You replace the case and gears but keep your input and outputs.
Justin
Old Nov 19, 2004 | 02:34 PM
fishmanndotcom's Avatar
fishmanndotcom
anyone want all the details on the only aftermarket gear set *trying* to become available needs to read through this thread and visit all the links...it has all your questions and answers
http://fordtrucks.com/forums/showthr...ighlight=lomax+
-cutts-
Old Nov 19, 2004 | 06:10 PM
ivanribic's Avatar
ivanribic
Well that settles that. Anyone want to take bets on how long it will take until I'll lose my mind and install a doubler in the Cap'n?
Old Nov 20, 2004 | 12:54 PM
hoxiii's Avatar
hoxiii
I know there was a company making 3:1's for the 203, anyone know if those are still available? If so that'd be the way to go, don't have to mess with your 205 but get a 2:1, 3:1, and 6:1.
Justin
Old Nov 20, 2004 | 01:20 PM
ivanribic's Avatar
ivanribic
Never heard of a gear kit for the 203 but I would be very interested in it if anyone can get some info. 6:1 would be a CRAZY crawl ratio . . . not like I need it but cool anyway. I could have compression braking with an auto!
samwe
Aug 5, 2004 03:51 PM
Franklin2
Jul 23, 2002 12:59 AM
Mar 5, 2002 08:06 PM
MSTRAWN
Mar 2, 2002 10:29 AM
whiteroc
Mar 21, 2001 06:37 PM
