Np205 transfer case leak
Old Mar 20, 2001 | 02:55 PM
whiteroc's Avatar
whiteroc
Old Mar 21, 2001 | 05:14 PM
big4294x4's Avatar
big4294x4
The front output yoke on my NP205 ( married to a C-6, in a 77 F-150 ) seems to be leaking. The leak seams to be coming from the peace between the front driveshaft and the transfer case. It is leaking from the seal closest to the transfer case. After warming the case up only slightly ( driving for 10 minutes ) it begins to leak. The leak is getting progressivelly worse. I believe the gasket between this piece and the transfer case to have gone bad, however I can't seem to get at the bolts to take it off. The crossmember is getting in my way. I cant take it off because it is welded on. Does anyone have any suggestions?
Old Mar 21, 2001 | 06:37 PM
Nathan's Avatar
Nathan
Its most likely the seal that seals around the yolk. They are not too bad to replace.
Nathan
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
1978 - 1996 Big Bronco
May 25, 2002 03:08 PM
broom
Nov 24, 2001 12:46 PM
