370 intake on 460
Old Nov 17, 2004 | 12:54 PM
BumbleB's Avatar
BumbleB
370 intake on 460
Good morning,
Can I use a 370 2 barrels intake on a 460 with a 4 barrels intake?
Thank's for the feedback.
veronique
Old Dec 6, 2004 | 11:33 PM
whd507's Avatar
whd507
yes. why?
68-72 mercury 429 2v intake would flow better.
better and cheaper yet, disconnect your secondaries, you then have a 2v carb no effort....
Old Dec 7, 2004 | 10:52 AM
Brad Johnson's Avatar
Brad Johnson
If you are trying to get better economy, then don't. Swapping to a 2V will not improve your fuel efficiency, it will just choke the engine at higher RPM.
It takes X amount of air plus Y amount of fuel to make Z horsepower. Swapping to a 2V carb will not change that. All it will change is the total airflow potential of your intake system.
The best setup is an intake/carb combo carefully matched to the airflow needs of your engine. That, plus a generally good state of tune, will return you the best economy (provided you keep your foot out of it).
Brad
Notmeofficer
Jun 2, 2013 10:37 PM
shanegr26
Sep 4, 2012 12:51 AM
370dumpman
Large Truck
Sep 27, 2009 10:06 PM
uniequipment
Aug 31, 2009 06:25 PM
BumbleB
Nov 24, 2004 01:58 PM
