Broken distributor bolt
Old Nov 17, 2004 | 08:06 AM
snipa's Avatar
snipa
Timing was off, I went to loosen the hold down bolt for the distributor, and the bolt snapped immediately-with little effort applied.
Worse yet, I drilled into the bolt, put in a bolt extractor (made in China I guess) broke also
Now I want to retap instead
My fear is the tapping the water jacket-How deep is the flathead area where the bolt goes in to hold down the distributor?
Old Nov 17, 2004 | 12:49 PM
mtflat's Avatar
mtflat
If you have the broken extractor out (never use those by the way) drill the remaining broken bolt out, oversize if necessary and use a bottoming tap instead of a starting/tapered tap. No need to go deeper in the original hole. If you stop just short of drilling out the original threads you may be able to use the original size tap and cut out the threads of the bolt with the tap.
Bottoming tap is straight sided with very little taper (only about 1 or 2 threads)
Old Nov 17, 2004 | 01:05 PM
snipa's Avatar
snipa
Thanks Mflat
I cant get out the broken extractor/bolt. I did pick up a 5/16" bottoming tap this morning at Grainger.
I dont know exactly how deep I can go, so I'll start at 3/16" deep and hope the newly tapped hole will grip the new bolt.
scseth
Feb 22, 2011 08:44 PM
nucleartruck
Mar 28, 2007 07:28 PM
broncofrk
Bronco II
Jun 14, 2005 01:44 PM
78Bill
Sep 8, 2002 03:03 AM
