For all you folks that need ujoints for your 4x. I found a replacement u-joint for at least the 4x4 steering shaft. It is not the exact thing, but works just fine.
The caps are just a very small amount smaller in daimeter, but still fit snug. The width of the joint where the groves are is a small amount wider. You will have to use a vice or a c-clamp to get them in there far enough to get the c-clips installed. Best of all it is greasable with the zerk in the same place.
