Steering u-joints
Old Mar 7, 2012 | 05:22 PM
3golfjack's Avatar
3golfjack
Steering u-joints
I have a question about steering u-joints. I am using three u-joints and a bearing mount with a 3/4 DD shaft. On the u-joints they come with two set screws and lock nuts. My question is the two set screws are two lengths. One appears to be made to go all the way thru the shaft while the second set screw length appears to be made just to butt against the shaft, everywhere I read it tells you not to drill all the way thru this shaft. So what is the correct way of mounting the u-joints on the DD shaft?
Old Mar 7, 2012 | 06:23 PM
rhopper's Avatar
rhopper
I didn't drill all the way through the shaft. My joints from borgeson said to dimple the shaft by drilling slightly into it where the set screw goes. I don't know why the screws are two different lengths. Use loctite and check for tightness when new.
ManfredVonRichtofen
30
Dec 21, 2011 06:37 PM
tbenks
Feb 20, 2010 03:03 AM
twofoolish2b
Jul 1, 2007 07:10 AM
superman64011
Sep 19, 2005 09:24 AM
Snowman671
Aug 19, 2005 01:26 PM
