Programming door locks
Old Nov 16, 2004 | 04:16 PM
forfan504's Avatar
forfan504
Hello,
I have a 2002, F-250 Super Duty. I would like to know how to disengage the "auto-lock" feature. i.e. the doors automatically lock once you start driving.
Help please...anyone?
Thanks!
Old Nov 16, 2004 | 04:48 PM
ib422goon's Avatar
ib422goon
door locks
I have a 03 & according 2 the owners manual you will have 2
1) Turn key to on and press UNLOCK button 3 times
2) Turn key off then press UNLOCK button 3 times
3) Turn key on again and within 5 sec press UNLOCK 2 times and lock 1 time
if done correctly you will get the horn to chirp 2 times for disable or 2 chirps and a honk for enable
Ed
forfan504's Avatar
forfan504
Arrow
hello....???
Old Nov 16, 2004 | 04:49 PM
forfan504's Avatar
forfan504
THANKS 422!!
I'm off to the parking lot to give it a try!
Old Nov 22, 2004 | 08:56 AM
forfan504's Avatar
forfan504
I get a short horn sound at the end of pressing unlock 3 times in the off position, but when I try the last step nothing seems to happen.
Old Nov 22, 2004 | 04:56 PM
tabasco's Avatar
tabasco
I havethe same truck and am getting the same results. Anybody had any luck with this.
Old Nov 22, 2004 | 07:24 PM
ib422goon's Avatar
ib422goon
door locks
I took the instructions from the owners manual and
have not tried it myself. So I cant help any more. Sorry
Ed
Old Nov 23, 2004 | 08:44 AM
rosa70's Avatar
rosa70
Here is what I used to program my 99 model.
All keyless entry remote transmitters must be programmed at the same time.
To program (or reprogram) the keyless entry remote transmitters into the Generic Electronic Module (GEM) , perform the following steps.
Turn the ignition from OFF to RUN five times within 10 seconds , ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
Old Dec 14, 2004 | 08:26 PM
mphymel's Avatar
mphymel
Question Doesn't work with my 02 350 either
Ed and Tabasco:
I tried that 3 unlocks- on, 3 unlocks off sequence and I get the same single chirp when I go back to on, and nothing after.
Does anyone know if there is a code book for these sequences. I am scared of screwing something up, either disabling something, or worse, frying something by cycling power so frequently.
Old Dec 14, 2004 | 08:29 PM
mphymel's Avatar
mphymel
Oh yeah, btw, Rosa70, I read and tried the method you mentioned, and I get the confirmation lock/unlock, but neither my FOB or my wifes explorer FOB work.
Does anyone know if the remote keyless feature can be disabled, like a jumper removed somewhere, or a relay pulled??
96_Powerstroke
Nov 20, 2014 11:05 PM
jo15765
Sep 6, 2013 10:15 PM
AlaTex
Electrical Systems/Wiring
16
May 18, 2007 05:23 PM
justwufn
Jul 29, 2002 06:05 PM
