Bronco II Ford Bronco II
ECC-IV codes
Old Nov 15, 2004 | 10:27 PM
twilightman's Avatar
twilightman
ECC-IV codes
Hello Everyone,
Have a 1984 B II 2.8L with 133.000 miles.
I pulled the codes,
KOEO- self test code 11
KOEO- continuous menory code 11,
KOER. code 12, 35, 58 74
any suggestion where to start looking to find defective parts.
Could these codes be caused by the TFI module?
One other question Where is the Brake on/off sensor located on this model
Thanks
Old Nov 15, 2004 | 11:54 PM
87 XLT's Avatar
87 XLT
After the engine code is flashed press and release the brake & your 74 will go away. Ater this the scanner will flash a signal to floor & release the throttle. Do this & your 12, 35 and 58 goes away
Old Nov 16, 2004 | 08:34 AM
twilightman
ecc-iv
Thanks for the information.
Guess I failed to mention I followed the test procedure, pressed the Brake pedal after the engine code, turned the steering wheel, then after the single code goosed the engine.
Cleared the codes and performed the test several times. always the same codes were present<O></O>
Old Nov 16, 2004 | 01:06 PM
87 XLT's Avatar
87 XLT
In that case you need to run the pinpoint tests for those codes. Wish i knew where to find them, maybe KenOO or one of the other guys will have them. One of the problems listed under 58 is "Idle tracking switch circuit failure" that might explain your 12 code?? I would'nt think a bad TFI would cause any of these codes.
What is the problem with it??
Old Nov 16, 2004 | 04:19 PM
cokoliso's Avatar
cokoliso
12, 35, 58 all could have something to do with idle.
What RPM is it idling at?
You don't have any of these codes stored in memory, so it doesn't seem to be happening while you drive.
Do your brake lights work? Isn't the switch down by the brake pedal?
Old Nov 16, 2004 | 05:56 PM
87 XLT's Avatar
87 XLT
I was wondering about the no CM codes also. Sounds like cokoliso has your answer, the idle speed probably is the problem. I took a look at that link, lots of good info there.
Old Nov 16, 2004 | 09:34 PM
twilightman
Thanks for the info Guys!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
The engine is idling about 750, according to the Sun Pro aftermarket tach,
I know these are not the most accurate tachs.<o:p></o:p>
This engine has the Motorcraft 2150a carb.<o:p></o:p>
There is a feedback control located on the back side of the carb,
is this the <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" /><st1:stockticker><st1:City><st1:place>ICA</st1:place></st1:City></st1:stockticker>?<o:p></o:p>
Also there is a throttle kicker assembly also called throttle stop positioner
of the side<o:p> </o:p>
<o:p></o:p>
I will look at the site and follow the Base Idle adjustment and the <st1:stockticker><st1:City><st1:place>ICA</st1:place></st1:City></st1:stockticker> testing and cleaning.<o:p> </o:p>
<o:p></o:p>
The symptoms it has are:<o:p></o:p>
It runs great for a while, and then the idle goes bad, <o:p></o:p>
When the idle is bad and you accerarate it feels like its fueled starved or running on 3 cylinders, then the engine picks back up and runs GREAT.<o:p></o:p>
This condition comes and goes at will. <o:p></o:p>
Neither heat or cold seems to influence it<o:p></o:p>
Can happen as many 6 or 7 times in a 6 mile drive to and from work, or it can run great for a week<o:p></o:p>
Yes the Brake lights do operate
Old Nov 17, 2004 | 04:33 PM
twilightman
Thanks for all the help.
I reset the idle per the web site and cleaned the ICA.
Everything is back to normal, will as normal as any Ford can be,
code 11 on all test!
again thanks
Old Nov 17, 2004 | 07:49 PM
Ken00's Avatar
Ken00
Glad to hear you got it fixed!!!
88 f150
Sep 23, 2021 07:55 AM
handsomerob
Jan 23, 2018 01:01 AM
4.9LOldFordTruck
Dec 16, 2015 11:32 AM
4.9LOldFordTruck
Dec 14, 2015 08:36 PM
jclopezv
Bronco II
Sep 9, 2004 07:53 PM
