Bronco II Ford Bronco II
KOEO Code 15?
Old Sep 7, 2004 | 05:20 PM
jclopezv's Avatar
jclopezv
KOEO Code 15?
Hi, I am getting Code 15 KOEO; It means: "Read Only Memory Test failed".
What can I do?
Old Sep 8, 2004 | 11:54 AM
87 XLT's Avatar
87 XLT
On my 87 Ranger the yellow wire at the EEC power relay supplies voltage to the ECA 24/7 It might be open.
Old Sep 9, 2004 | 07:53 PM
Ken00's Avatar
Ken00
A code 15 will be set if you disconnect power to the ECU, clear the code per the procedure and see if it comes back. If it does check for B+ at ECU pins 1 and 40 or 60, if thats OK there's a ECU problem.
texasyakfisher71
Aug 3, 2010 01:30 PM
fordman1090
Sep 28, 2009 06:09 PM
MemOrex
80
May 29, 2008 09:04 PM
danield
Mar 5, 2008 09:43 PM
el conquistador
1983 - 2012 Ranger & B-Series
13
Apr 27, 2004 10:53 PM
