Power lock wires
Old Nov 15, 2004 | 09:13 PM
unluckylow's Avatar
unluckylow
Power lock wires
Hello, looking to see if any one out there knows what color the lock and unlock wires are on a 2000 PSD XLT. I know it is a five wire positive setup. I went to 12volt.com and there colors dont match. Just curious if anyone out there out there has installed an after market alarm. its just two wires one for the unlock and one for the lock.Any help would be great.
Old Nov 15, 2004 | 10:52 PM
realhp's Avatar
realhp
The unlock wire color is Pink/light green and the Lock is Pink/Yellow. This is straight out of the factory manual so let me know if you have a problem.
Old Nov 16, 2004 | 07:31 AM
unluckylow's Avatar
unluckylow
Thanks realhp, Yeah thats what the web site said, but I looked every where and cant find them, you dont know where the harness is? I was told it was above the accelerator pedel.There is a plug on the pedel and I think it has those two color wires but I think that is for something elese. Any ideas.
Old Nov 16, 2004 | 12:04 PM
kevin265's Avatar
kevin265
unluckylow, I work in a Stereo shop, I'll look it up and have an exact location for you tonight.
Old Nov 16, 2004 | 12:23 PM
unluckylow's Avatar
unluckylow
Thanks Alot that would be great.
Old Nov 16, 2004 | 06:33 PM
kevin265's Avatar
kevin265
Unlucky, Drivers kick panel. Pull the plastic kick panel and you will see a bunch of wires. You should be able to pull the loom out to get at them. The easiest way to test to see if you have the right wire is to use a test light. The locks are negative trigger so, you attach the clip of your test light to a GOOD ground when you pierce the right wire the locks should go up or down depending on which wire you trying. The nice thing about using the test light is if you hit a wire carrying +12 it just lights the test light up and no sparks! Good luck, if you run into any probs let me know.
David Hewitt
1997 - 2003 F150
Dec 31, 2013 10:39 PM
jjs2032
Apr 22, 2008 08:27 AM
kert
Sep 14, 2007 10:43 PM
K2JJB
Electrical Systems/Wiring
Jun 15, 2004 11:05 PM
RogueRiverRat
24
Dec 1, 2003 09:33 PM
