Wierd front axle noise
Old Nov 15, 2004 | 07:27 AM
Cuda_jim's Avatar
Cuda_jim
Re: 1996 F350 Crew cab 4x4 PSD. 164K miles
I've noticed a strange noise coming from the front drivers side axle when appling the brakes in a slow turn (like parking the truck). The brake seem to hold on a bit after the pedal is released then the noise happens but disappears after the wheel is straightened. I'm thinking it's stuck caliper sliders. Nope, Read on.
Poking around the hub area, I noticed a bunch of axle movement side to side in the truck. A tear down discovered that the 1st snap ring you come to during disassembly was missing. Yep, that's my problem!
Now for the wierd part. There is no snap ring groove machined into the stub shaft. Guess that explains why there's no snap ring.
This truck came from the factory without a snap ring & groove! Are there stub axles out there that don't need the snap ring????? All of the front axles I've worked on has 'em.
The dealer says all I can get is the entire axle shaft assembly @ over $400. Holy, crap!
Anyone know where I can get just the stub axle?
Sorry for the long post, but I thought that this info might help others diagnose a possible brake problem that ain't a brake problem at all.
Old Nov 15, 2004 | 08:16 AM
Kwikkordead's Avatar
Kwikkordead
Just a stub axle? Suggest a junk yard.
Old Nov 15, 2004 | 10:18 AM
Cuda_jim's Avatar
Cuda_jim
Kwik, Did that. No luck. Seems that the F350 fits ONLY the F350. Lots of 250 axle parts.
Thanks,
JIM
Old Nov 15, 2004 | 09:56 PM
Kwikkordead
Thanks,
JIM
Bummer.
Old Nov 15, 2004 | 10:23 PM
realhp's Avatar
realhp
There is a place here in Albuquerque that can get you what you need, the name is Drive Train Industries. If you would like I can call them and see how much they can get you one for. They have been able to get me stuff that everybody said dealer item only.
Old Nov 15, 2004 | 11:55 PM
Racerguy's Avatar
Racerguy
The mono-beam F-350 front axles don't have outer snap rings. The axle is kept from going in too far by the cross shaft in the diff.
The noise you're describing sounds like a seized axle u-joint.
Old Nov 16, 2004 | 05:22 AM
Cuda_jim's Avatar
Cuda_jim
realhp, thanks, I'll give em a try. I've posted a request acouple times at a parts finder for scap yards with no luck.
Do you have the PH#?
Thanks again for all the help.
Old Nov 16, 2004 | 05:34 AM
Cuda_jim's Avatar
Cuda_jim
racerguy, Great info, But Axle u-joint a nice and free. Decided to check all Front axle wear parts. I tore the other hub apart last nite.
It has a snap ring!
I bought the truck used so anything goes. BTW It has Warn manual hubs. Previous owner must have replaced the Auto Locking hubs. Was glad to see that.
I'll open up the housing today and post the findings.
Thanks for all the input.
Old Nov 16, 2004 | 10:01 AM
realhp's Avatar
realhp
Here is there number 505-341-2332 when you call ask for Loyd and tell him that Robert from The Works Auto sent you to him.
Old Nov 16, 2004 | 11:15 AM
Cuda_jim's Avatar
Cuda_jim
realhp,
In the true fashion of a Great Web Site you, the members, always come through.
Thanks for the ph#. I will call Loyd
Thanks again,
JIM
Old Nov 16, 2004 | 04:59 PM
Level2's Avatar
Level2
I had a 97 F350 that made a similar noise....turned out to be bad ball joints. You probably already checked that but I thought I would toss in my 2 cents.
Old Nov 16, 2004 | 11:14 PM
realhp's Avatar
realhp
Cuda_jim, did you get a hold of Loyd?
Old Nov 17, 2004 | 05:03 AM
Cuda_jim's Avatar
Cuda_jim
Ball joints were replace 5K ago.
Thanks, JIM
fifty-two_f1
May 2, 2023 01:37 PM
fordf2501
Mar 21, 2017 07:51 AM
AIbandit
Apr 29, 2016 02:34 AM
dpilot83
Dec 23, 2015 09:43 AM
ccoram
Mar 28, 2008 03:16 AM
