View Poll Results: Do you use a block heater? Do you pre-heat/idle your 6.0 prior to driving?
Block heater all night?
80.00%
Pre-heat the engine?
25.71%
Remote start to pre-heat engine?
8.57%
Fire it up & drive it cold?
11.43%
Multiple Choice Poll. Voters: 35. You may not vote on this poll
Block heater, How warm should it be?
Old Nov 14, 2004 | 09:00 PM
jackofalltrades's Avatar
jackofalltrades
I've thought about putting my block heater on a timer. Just to apply it a couple hours before I get up in the morning. Temps are only in the low 40's nightly here right now. But I figure on less engine run/warm-up time before my work commute. I left it plugged in all night the other night. No movement on the temp guage. All others I've had in the past at least get the engine coolant warm, -above 100° or so.
It takes nearly 20 minutes to get to full operating temp from a cold start whether I use the heater or not. Any hints?
Old Nov 14, 2004 | 09:06 PM
huntercgr's Avatar
huntercgr
Are you just letting it sit during the 20 minutes or driving it? We've been in the low 30's and I'll just let it warm up for about 5 minutes and then start driving it easily, as in below 1500 RPM's, and it then takes about 5 minutes to hit normal operating temp.
Oh, and this is without plugging it in.
Old Nov 14, 2004 | 09:19 PM
jackofalltrades
Tough to keep Rpm's low out of my driveway.
Unfortunately I live on a 55mph rural busy highway. Even with the 6spd, it's difficult to keep R's below 1500 when I pull out. It's safest to get up to speed as soon as possible. Especially if it's a bit foggy. So, yes, my warm up time is at idle in the driveway. I'm looking for a grill block-off mat that snaps in place to limit air flow. That might help too? I was hoping that the block heater would have the temp guage up at least half way when I fire it up.
Old Nov 14, 2004 | 09:20 PM
arcturner's Avatar
arcturner
Before installing my timer, when the heater ran all night, my temp gauge was 1/3-1/2 of the way to normal operating temp. After the timer, running just 2 hours prior to starting, it still takes a few minutes of running to hit the same spot. I just adjusted it tonight to add another hour. We'll see what happens.
Old Nov 14, 2004 | 10:25 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Here is the anser you may have been looking for (and note the "at least 3 hours part)...
Use of an engine block heater is strongly recommended if you live in a region where temperatures reach -23° C (-10° F) or below. For best results, plug the heater in at least three hours before starting the vehicle. The heater can be plugged in the night before starting the vehicle. The plug for the block heater is exposed in the front of the vehicle, beneath the grille. Vehicles equipped with a gasoline engine have the plug exposed on the driver side of the vehicle; vehicles equipped with a Diesel engine have the plug exposed on the passenger side of the vehicle.
Hope this helps,
Jeff
Old Nov 15, 2004 | 05:01 AM
t_j82's Avatar
t_j82
I usually leave mine and my wifes plugged in all night. It doesn't use THAT much power and I don't have to worry about any timer failure or electronic glitches. I have noticed (at least on my '02) that it doesn't get toasty warm but allows the motor to turn over easily. I don't like to leave mine idle for any longer than 10 mins or so because in the early hours it tends to tee off the neighbors because of echo. I have not had the chance to try the '05 yet, but I will within the next 3 weeks since we are leaving here for the frozen north
Old Nov 15, 2004 | 01:08 PM
jackofalltrades
Block heater plugged in last night..
I guess it does raise the temp a bit. I left it plugged in all night. I'll try a timer setting that'll give me 3 hours of warming. Anyone know how many amps the heater draws?
Old Nov 15, 2004 | 04:04 PM
mikewrt's Avatar
mikewrt
The heater draws around 8.5 amps. The heater is around a 14 ohm resistive load.
V=I*R ====> 120V/14 = about 8.5 amps
This then equals over 1000 watts of power.
Power = V*I ====> 120V*8.5 = 1020 watts
I use a timer that comes on when the temps get low enough.
Old Nov 16, 2004 | 04:45 PM
iceman5's Avatar
iceman5
Preheat
I plug mine in at 40°F to a timer set to come on about 4 hours before I leave in the morning. My temps at start-up have been about even with the C on the temp gauge. About the only difference I notice is that the engine is not near as noisy when I have it plugged in than if I start it cold.
Old Nov 16, 2004 | 04:54 PM
jackofalltrades
Preheat
Thank you Mike. I'll be sure to find a timer rated for at least 1500watts then.
Iceman, that's what I guess I'm noticing. There is a rise in the temp needle now that I look at it closer, and yes, there is a definate difference in the sound when firing it up in the morning. Not the cold sound of a hammering diesel.
So, are there any camps out there that wouldn't endorse the use of the block heater below say,... 45 degrees. My brother'n law with a 00' 7.3, was told by the local dealership mechanic not to use his block heater unless it got well below freezing. Any thoughts on that?
And shame on the rest of you that just fire yours up and drive it cold.!!
Old Nov 16, 2004 | 05:42 PM
Rearview's Avatar
Rearview
I plug mine in all night when it gets to be under 35 deg.
Any other time I come out start it up, back out of the garage, come back inside and take the morning meds, grab my lunch and a quick bite. grab the coat and out the door. About 5 minutes idle B-4 driving.
Idleing for 5 minutes, I normaly have heat within the first 3 miles.
Pluged in, I have heat before the end of the driveway.
Just a theory here, Better to maintain a temp, rather than to try to reach a temp?
Just a thought.
Old Nov 16, 2004 | 05:55 PM
Ben Alston's Avatar
Ben Alston
I will plug mine up all night if it gets down in the 20s and low 30s and if its above 35 I will let it warm up for about 5 min then drie it easy
Old Nov 16, 2004 | 08:02 PM
rocknut's Avatar
rocknut
I don't plug mine in till it's below freezing. It's been below freezing a few nites latley, the other morning it was 19 and I didn't plug it in and it started fine just a little bit of smoke at start up. On my 99 7.3L I would just plug it in all nite when it was below freezing. I still let it warm up to thaw the windows and warm the seats. If it's above freezing I don't even worry about it. 40 degrees is warm weather for us in Ohio during the winter. We even drive around with our windows down!!!
Old Nov 17, 2004 | 05:14 AM
t_j82's Avatar
t_j82
I plug mine in all night when it is supposed to drop below 25 or 30. Much easier starting. I agree with the statement above, it is easier to maintain heat than to make it heat so on that note I try to plug it in right after I have driven it for the last time that day.
Solaratrd
Feb 1, 2012 11:12 PM
k_nine
15
Mar 6, 2011 01:43 AM
Jeffypop
Jan 25, 2007 11:42 PM
SteelRollin
34
Oct 30, 2006 02:25 PM
fordmtnman
May 25, 2005 09:21 AM
