Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
anyone using a husky/ch air compressor?
Old Nov 12, 2004 | 10:19 PM
84-250's Avatar
84-250
since i'll be sandblasting my truck next summer instead of this fall due to a garage fire, im also gonna need a new air compressor. anyone use the campbell hausfeld iron force (from lowes) 11cfm @90 or the husky brand from home depot? i was going to get an IR ss3l3 but its $570 instead of $429 for the campbell.
anyone have one of these?
Old Nov 13, 2004 | 12:21 AM
fixnair's Avatar
fixnair
If the "CH" in your brand name means "Cambell Hausfeld" it will be a pretty good air compressor as hardware variety goes. Do get a two stage unit though. Change oil every 500 hours and clean the air filter often, monthly and it should last a long time. The only problem with the hardware variety is the lack of parts backup. If it breaks down you may have to wait a long time for parts or even worse you may find they dont supply the parts any longer.
Old Nov 13, 2004 | 06:58 AM
bimmerbill's Avatar
bimmerbill
I was just checking out the Husky compressors at Home Depot. They say that they are made by CH.
Old Nov 13, 2004 | 08:43 AM
84-250's Avatar
84-250
i was planning on getting the one for $429
model#vt6329
11.8@40psi
10.3@90psi
oil lube
60 gallon
100% solid cast iron pump
5000 hrs pump life
3.2 running hp
220v
single stage
i plan on running mobil 1 in it, as they do allow syn motor oil
Old Nov 13, 2004 | 09:05 AM
bimmerbill's Avatar
bimmerbill
I am leaning toward that one too. I was just looking for any 10% off Home Depot coupons... Couldn't find any tho.
I don't know much about compressors. Would I have to add any valves or anything? Or does it come all set, and I can hook up a hose and tools and start using it?
Old Nov 14, 2004 | 10:34 AM
marilyn's Avatar
marilyn
ch compressor
I have the 2 stage 18cfm@90psicost 950.oo piped it with copper have had it a year will do hvlp paintjobs no problem havent tried sandblasting yet. mike
Old Nov 15, 2004 | 10:55 PM
wot302's Avatar
wot302
Try your local Harbor Freight store. They have a decent looking compressor for less than $400 that pumps 14.5cfm@40, 12.8@90.
Old Nov 16, 2004 | 09:42 AM
Huntsman's Avatar
Huntsman
I have the Husky single stage from HD. The best I can remember, it is a 6.5 HP 60 gal upright tank. It has done a decent job though it was pushed very hard in sand blasting my frame and sheetmetal, dropping to around 80 PSI max for continuous wide open use with my 80# pressure feed HF sandblaster using the smaller ceramic tip. I painted the complete truck using it and a 7.9 CFM gun with no problems.
With most of my intended projects complete and the compressor collecting a little well earned dust, I'm glad I bought it. If you have plans for more professional or insdustrial use, I would buy a two-stage pump.
Old Nov 16, 2004 | 12:49 PM
koconno2's Avatar
koconno2
I'm leaning towards the CH at Lowe's. It's a 60 gal, single stage, three piston cast iron pump, 5Hp and I believe the recovery rate is about 12 cfm @ 90 psi. I have been shopping around and to get a 12 cfm in a single stage for $650.00 is not a bad deal. All the two stage 60 Gal compressors with cast iron oil type pumps are about $1100.00 +/- $200. Craftsman has a two stage 60 Gal, oilless compressor for about $500. I have a small 30 Gal oilless compressor now and it's very noisy.
I would be leery of single stage compressors that clamed to deliver 12+ cfm for less then $500.00. I have not found these features on a name brand compressor for less then what Lowe's has. If the Harbor Freight compressor is truly a robust unit then that is a great price at $400.00.
I have been burned buy so called assume deals from Harbor Freight. You get what you pay for.
Old Nov 19, 2004 | 01:02 PM
Bart99GT's Avatar
Bart99GT
The 60 gallon 10.2 SCFM CH compressor at Lowe's runs about $30 cheaper than the one at Home Depot and has the same specs. I'm looking at getting the Lowe's one after Christmas probably.
Does anyone know if that compressor (VT6329) will be able to tackle small sandblasting jobs, such as removing the paint on the hood of my Ranger? It looks like as long as I purchase an oil/air seperator it should do fine for repainting my truck.
Bart
Old Nov 19, 2004 | 01:27 PM
koconno2's Avatar
koconno2
Technically any air compressor will run a sand blaster for a given period of time. The question you need to ask is how long are you willing to wait for the tank to refill. Your sand blaster gun should have a recommended flow or consumption rating. If the gun is rated at 15 cfm @ 90 psi and the compressor is rated at 10.0 cfm @ 90 psi you must stop when the pump turns on and wait till it shuts off. But a larger volume tank will also give you a longer work time in between recovery periods. You can still blast your body panels with good results but it will just take a little longer. Nothing wrong with that for home use.
Old Nov 19, 2004 | 01:58 PM
zuikoman's Avatar
zuikoman
You can get the bigger compressors with none of that and save money or you can get ones with all the built in controls for more money.
I got one with no plumbing for about 1/2-2/3 of the price of the same motor and pump on a 25% larger tank with the controls. That was a no brainer in my book.
Old Nov 19, 2004 | 02:15 PM
skonnie-mark's Avatar
skonnie-mark
You can also check chpower.com for reconditioned deals - the $429 HD version is $375 delivered from the site.
Old Nov 19, 2004 | 03:18 PM
Cliffdog's Avatar
Cliffdog
Hey Fellas... I Know Im The New Guy...but Im Also The Parts Guy..if Your Gonna Purchase A Compressor Stay Away From The Remans...most Have Little Or No Warranty...and Please Spen The Money On A Cast Iron, Oil Lubricated Unit..the Small Oilless Units Are Ok Fer Grandpa..but Basically Junk Fer Automotive Tolls And The Like..
jtlinn1975
Garage & Workshop
Jun 25, 2014 11:43 AM
SBastow
Garage & Workshop
Feb 9, 2012 04:22 AM
ferguson777
Garage & Workshop
Jul 27, 2005 02:43 AM
GotLift
Garage & Workshop
22
Jan 7, 2005 11:29 AM
CRJ900
Jan 14, 2002 05:39 PM
