Modified air-box
Old Feb 2, 2005 | 07:59 PM
castman's Avatar
castman
That cheesy little tube tube from the air filter box to the grill may not look like enough, but it will flow more air than your stock intake and exhaust manifolds will. All you've really accomplished is to draw in warm air from the engine compartment instead of cooler outside air in through the cold air duct. Once you've had a port and polish job done, then you may see a further increase in horsepower by opening up your intake some. Until then you're probably better off returning it to the way it came from the factory so it will function the way it was designed too.
Sorry to rain on your parade.
Old Feb 2, 2005 | 08:38 PM
19903024x4's Avatar
19903024x4
how much does it usually cost to get the heads ported and polished?
derek0525
Jul 8, 2016 04:28 PM
rollinXplorer
Feb 26, 2005 12:12 PM
ford97sohc
Feb 23, 2005 03:56 PM
4.9LFord
Feb 2, 2005 07:22 PM
stanggt
Apr 3, 2004 11:07 PM
