transmission kickdown
Old Nov 9, 2004 | 10:55 AM
ford390gashog's Avatar
ford390gashog
i installed a holley 4160 on my 390 in my 75 supercab and there is no way to attach the kick down what happens if you drive it with out the kick down
Old Nov 9, 2004 | 11:44 AM
66f14evr's Avatar
66f14evr
your probably going to be without your passing gear
Old Nov 9, 2004 | 12:16 PM
ivanribic's Avatar
ivanribic
No harm in it, you just have to manually shift to 2nd when passing. Or you can buy a cable kickdown from Lokar for around $50. This will allow you to use the kickdown with any carb setup.
Old Nov 9, 2004 | 12:17 PM
beartracks's Avatar
beartracks
The linkage for the kickdown is part of the throtle shaft and not really retrofitable. Lokar makes a cable kit.
Old Nov 9, 2004 | 01:57 PM
ford390gashog
yeah i saw you have to change the whole shaft summit sells the correct one for 30.00 could someone tell me just how this works the one on my 2bbl that i replaced just kind flooped around and didn't do much how does it work
Old Nov 9, 2004 | 02:18 PM
ivanribic's Avatar
ivanribic
When the throttle is open all the way it pushes the rod back and down. The rod pushes the kickdown lever on the tranny which makes is downshift. If you switch to a Lokar cable you flip the arm around on the tranny and set it up to pull the lever instead.
Old Nov 9, 2004 | 02:45 PM
RR4E's Avatar
RR4E
I might add that the kick-down set-up also changes the amount of pressure on the trans fluid, where manually shifting does not. It'd be better to do the conversion and make it work the way it's supposed to.
Old Nov 9, 2004 | 03:58 PM
dfisher1's Avatar
dfisher1
All,
Holley makes the kick down likage kit. You can order a carb that has it on already. Strangely, the linkage just flops around until you hook it up. This means that the linkage does not move until you really get into the throttle. Unfortunately, you will have to dissassemble the Holley to install the linkage. This is extremely painful. The screws on the throttle plates are cross threaded to ensure that they never fall out. It is possible/easy to strip them getting them out and getting them back in.
I did mine with no problem, (YEAH RIGHT!)
Good Luck, you'll need it,
KingFisher
Old Nov 9, 2004 | 04:47 PM
ford390gashog
thanks i found out today there were cross threaded
sweetlou1
Nov 6, 2014 08:21 AM
9d4
Oct 25, 2009 11:00 AM
big 390
Jul 21, 2007 10:56 AM
76 F-150 390FE
May 3, 2006 09:44 PM
MRStace84
Sep 16, 2005 08:27 AM
