Starting Problem
Old Nov 8, 2004 | 08:55 PM
dieselfam's Avatar
dieselfam
Unhappy Starting Problem
Got it towed today. Would not start. It turns over a few times but then it almost sounds like its out of time. Last time it did this I let it sit all night and it started fine the next morning. This time it left me stranded at work. Has anyone else experienced this problem? 03 KR 6.0 PSD 4WD
Old Nov 8, 2004 | 09:01 PM
SBV45's Avatar
SBV45
Could be a number of things like ICP sensor, failed high pressure pump, on and on. Let us know what they tell you is wrong.
Old Nov 8, 2004 | 09:10 PM
dieselfam's Avatar
dieselfam
Red face Maybe Tommorrow
Hope that I hear something tomorrow. By the time the wrecker got there tonight the dealership was closed upon arrival. Truck has 20,286 miles on it. Hope that I can get the bugs worked out before the factory warranty retires.
Old Nov 8, 2004 | 09:18 PM
SBV45's Avatar
SBV45
Factory warranty on the engine is 100K. On the rest of the truck is 36K Try to get them to give you an extended warranty for your inconvenience.
Old Nov 10, 2004 | 08:49 PM
dieselfam's Avatar
dieselfam
Talking Fixed it
The dealership replaced the fuel injection control module, reprogrammed the PCM and TCM using WDS. Starts okay now. What's PCM and TCM stand for? What's a WDS. If they reprogrammed the PCM and TCM do they mean that they actually changed code or did they just reflash the modules?
Old Nov 10, 2004 | 08:56 PM
SBV45's Avatar
SBV45
PCM=PowerTrain Control Module, TCM=Transmission Control Module. WDS is the Ford computer program system. The FICM (Fuel Injection Control Module) is closely integrated with the PCM and TCM. So yes they had to have the firmware (flash) reinstalled. They installed the latest firmware (flash).
Old Nov 10, 2004 | 09:09 PM
dieselfam's Avatar
dieselfam
Thanks
Thanks for the education.
Old Nov 10, 2004 | 09:27 PM
dieselfam's Avatar
dieselfam
reflash of the TCM and FICM
With this reflash will my truck see a decrease in mileage and power? I did think that it was a little louder when I picked it up. I've read other post where other owners experienced these problems.
Old Nov 10, 2004 | 11:17 PM
SBV45's Avatar
SBV45
I just got the latest one for the 03's. I think the lower end response and accelerator pedal response has improved. It feels more like it did when I bought it. I am still running it to see if there is an increase in mpg.
gscoull
Jul 11, 2012 09:14 PM
dwrestle
Sep 3, 2006 07:38 PM
uk1050
Feb 13, 2006 07:11 PM
pbakala
Aug 22, 2004 10:35 AM
superman0604
1978 - 1996 Big Bronco
22
May 28, 2004 01:34 AM
