cb mount??
Old Dec 12, 1999 | 04:41 PM
Adam_1's Avatar
Adam_1
cb mount??
I just bought a Cobra Cb for my 87 ranger and can not find a place for it. I would put it in between the steeringwheel and the glovecompartment but there is not room. Plus, if i did, i could not take the mic off to talk. also the wires that go to the fuse box and ground are short so i have to put it somewhere close. any suggestions on what i should do??
Old Dec 16, 1999 | 02:22 PM
Chuck P.'s Avatar
Chuck P.
cb mount??
I've mounted mine overhead in an 83, ran the antenna thru the roof about center, extended the wires with crimp type butt splicers and ran them down the channel inside the trim piece to the fuse box. This kept the mike within easy reach and made for a "clean" installation. Mine is a little cramped down at the dash also. One alternative for the antenna is to use a consealed unit, nothing more than a duel plug arrangement with one side for the radio and another for the CB which uses the FM antenna in the stock location. Chuck P.
Old Feb 8, 2002 | 11:32 AM
black_ranger's Avatar
black_ranger
cb mount??
I had the same problem with my Ranger. Considered putting it on top but didn't want to.So we tried something a little unusual. I mounted it under the dast in front of the stick shift using foam tape on the mount to hold it up. I've had it mounted for about six months now and have not noticed any problems with it slipping or falling off.
Old Jul 2, 2002 | 02:57 AM
redline1's Avatar
redline1
cb mount??
Here is a GOOD way to install a cb in a ranger. Install it in front of the stick. Use longer screws (in place of the ones that secure the shifter boot)to hold your cb bracket. Brace the bracket where the dash support bolt is (infront of the shifter) with a steel bar. To gain extra clearance behind the cb you can get a 90 degree fitting from a radio supply shop. I built a custom antenna mount in front of the hood. I made the mount bolt to existing unused threaded holes near the hood release. It is supported below by my fog light brackets. To add fog lights without drilling holes, just make 90 degree brackets that secure (between the bumper and the grill) to front bumpers upper mounting bolts. It took about a day to make the cb mount bracket, the antenna mount, the fog light mounts, the antenna support bar, and to install it all. It works good, and no holes needed to be drilled into the truck.
Old Jul 2, 2002 | 10:27 AM
propellerhead's Avatar
propellerhead
cb mount??
I bought the Cobra CB that has everything on the mic. The channel selector, the volume, squelch, etc. I didn't have to mount anything.
But I did have a regular type CB in my Mazda before. I used double-sided tape. Worked great!
Old Jul 2, 2002 | 09:49 PM
Sawbones25's Avatar
Sawbones25
cb mount??
If it helps,
I have a Northstar 3000 (same thing as a Galaxy 33) mounted in my 95 Ranger. I removed the ashtray and it fits in the void. It's mounted up at a 45 degree angle, and the mic cord goes around in front of the shifter to the clip on the other side of the CB.
I know the interior is different, and I'm not sure where the ashtray is in your truck, but that may be a possible option if you don't use your ashtray.
Old Jul 2, 2002 | 11:29 PM
Mil1ion's Avatar
Mil1ion
cb mount??
In 2 1/2 years(date of original post) I hope it has been installed and used.
I hope the info helps others though.
[font color=red]Dennis
FTE Adminstration
[/font]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
Old Jul 3, 2002 | 08:46 AM
Cope's Avatar
Cope
cb mount??
conderd
119
Feb 25, 2023 01:24 AM
TWF23
Jul 8, 2022 11:07 AM
Django.Amadeus
Jan 1, 2016 04:29 PM
Cameronc0316
Electrical Systems/Wiring
Mar 29, 2015 07:25 AM
ramirezbrandonc
Aug 22, 2014 04:45 AM
